I had been going back and forth with Eric Larson from Enphase. According to him, his engineers believe that their inverters will NOT interfere with UPB, but MIGHT with X10.
They were putting together some white papers, never did hear back from them on that. Eric told me that they were trying to get out a new unit (which did get out for sales), so, maybe I should follow up with him.
The main issue with their stuff, is you can have their base unit, which talks to each inverter to get statistics. I thought that might interfere with my UPB. The big suggestion there is to just not use the base unit, which then the other units (which are polled) will not talk. The thing with that is, you loose out on being able to see the efficiencies of each panel and track power use for each panel over time. Neat idea.
I also liked their units as they can be installed piecemeal. One per panel. I was also considering using one of their units as a power inverter from a battery rack. Seemed a bit more cost effective to use those.
Price per watt looked decent (not HUGE savings, but you did not have to put in DC carrying cables from the panels on the roof, nor did you have to buy HUGE units just to have enough watt-conversion capability for the future. With these, you just keep adding them in parallel to get the wattage that you need (i.e. one per panel).
--Dan
