UPB Driver
#1
Posted 13 October 2008 - 03:51 PM
Anyone willing to help me with the UPB driver. I have installed the driver all seems well. Driver saw all my devices as I think it should. Now what. How do I link a Premise device to the devices that show up in the driver. They don't appear as options when I go the the Premise device and try to bind them to something. Are there any instruction for using this driver. I'd really appreciate any help you'd be willing to give.
BB
#2
Posted 13 October 2008 - 06:12 PM
If they are showing up as unknown, I've never been able to get them to work, as Premise doesn't know what they are. So that means that there are only a few items that actually work, those that are specifically coded into the drivers.
Which UPB devices do you have?
#3
Posted 14 October 2008 - 05:04 PM
Are your devices showing up as unknown devices? Or do you actually see device model numbers, etc.?
They show up as unknown devices. Are you saying that is the driver recognized the device it would show up when I try to bind a light object to it. If so do you know what particular Model upb devices that the driver can use.
BB
#4
Posted 14 October 2008 - 08:18 PM
The supported models are hard coded. And the drivers were done years ago. So they support Simply Automated and PCS.
If you go to the Builder > Devices >upbSA or upbPCS and look at the Product ID List on the Properties sheet, it will tell you which items are included for each driver.
What products are you using?
I wish I could code, because I would just write a driver. But I'm just starting to learn VBScript. So it'll be a while before I get there. Plus it would be nice if we had a driver that could just use the UPStart export file instead of hard coding.
#5
Posted 14 October 2008 - 09:16 PM
#6
Posted 14 October 2008 - 09:37 PM
Do you even have any UPB devices?
Please let me know if I can help.
#7
Posted 12 January 2011 - 02:40 PM
#8
Posted 12 January 2011 - 03:43 PM
Then go to Devices. You should see a UPB device as well as the subs you added. Right-click the UPB device an add the type of interface you are using (Serial, USB, TCP). That should do it. It will scan your UPB network and add the items it finds. If you do not get anything showing up, you may need to manually add a PIM device by right-clicking the upbSerialInterface (or USB or TCP) and adding a PIM.
Should look something like...
Edited by samgreco, 12 January 2011 - 03:45 PM.
#9
Posted 12 January 2011 - 10:44 PM
#10
Posted 12 January 2011 - 10:58 PM
Also, understand that this driver is VERY old and does not support a lot of newer UPB devices. What UPB devices are you using? Especially the PIM?
#11
Posted 12 January 2011 - 11:13 PM
#12
Posted 13 January 2011 - 01:02 AM
#13
Posted 13 January 2011 - 01:09 AM
Edited by nov0798, 13 January 2011 - 01:14 AM.
#14
Posted 13 January 2011 - 09:12 AM
If you have an open serial port on your PC, you may want to bypass the Elk and connect directly just to see if everything is working.
#15
Posted 13 January 2011 - 10:34 AM
Elk M1G Lighting: If you have the UPB stuff working in ElkRP (i.e. with the Elk alone), I think the Elk module in Premise will be able to actuate the lights, but you may have to set up some parameters for the lights to be discovered. I don't have Premise in front of me, but I think the container under the Elk_M1G module is labeled something like PLC. I'd recommend reading 123's instructions for the Elk M1G module and see if it talks about lighting. I don't use the Elk for lighting control, but I know that lighting control is a feature of the 123's Elk M1G module.
Edited by etc6849, 13 January 2011 - 10:35 AM.
