Jump to content
Structured wiring can compatability/On-Q ethernet depth
  • Please log in to reply
11 replies to this topic
#1 Scott Crawford
Scott Crawford
    Newbie
  • Registered
  • Pip
  • 3 posts
Posted 31 March 2009 - 03:23 PM
I'm going to install a structured wiring enclosure in my basement for my growing cat5 farm.
I'm wonder which manufacturer's modules work in other manufacturer's cans. ie...can I take a Channelvision module and put in an On-q enclosure? Can I take a Leviton module and put in an On-q enclosure? I'd like to use the as-designed mounting holes/tabs. In looking for a picture for my next question....does ChannelPlus modules fit in an On-q enclosure?
I have an On-q enclosure that I just picked up, still in the box. Wondering if I need to further research the modules I might want down the road...and maybe return the On-q.
My second question is this....
I got a few on-q 6-port data modules like this http://www.amazon.co...e/dp/B000JWQJX6
There is a pretty good offset to support the back-wiring of the keystone jacks. I'm concerned about the RJ45 cable that I plug into one of these jacks being bent/stressed by the enclosure cover. Maybe I'm overthinking. I'm soliciting opinions before I open things up and make returning more of an ordeal.
Thanks for any opinions...answers
Scott
#2 MavRic
MavRic
    Cocoonut
  • -=Platinum Supporter=-
  • 1164 posts
Posted 31 March 2009 - 04:29 PM
These things have 110 punchdown on their backs so that you terminate the cate on there. Thats is why there large offset is there. The fron you then use to connect it to to switch or router.
If it's a OnQ part and an OnQ panel i woudl imagine they did their homeword....not sure if it would work both with and without strain relief 'boots' on a patch cable since that makes it stick out more.
#3 royalj7
royalj7
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 382 posts
Posted 22 April 2009 - 07:15 AM
Surprised no one picked the first part of this up. On-q enclosures/modules are compatible with On-q and Grayfox. Leviton is compatible with ChannelVision.
--Jamie
#4 Scott Crawford
Scott Crawford
    Newbie
  • Registered
  • Pip
  • 3 posts
Posted 22 April 2009 - 07:19 AM
--Jamie
Thanks Jamie.
That was the most frustrating quest for information. I ended up with an On-q enclosure. Now I'll go look at any different modules the Grayfox has.
Have a great day.
#5 MavRic
MavRic
    Cocoonut
  • 1164 posts
Posted 24 April 2009 - 07:22 PM
Maybe somebody can confirm, but my observations are as follows:
I have a Leviton can and some Channelvision and OnQ ALC modules. The Channelvision modules DO NOT fit in a Leviton can without drilling some extra holes, but it appears the Leviton modules would fit in a Channelvision can without any trouble. ELK stuff is compatible with both Channel vision and Leviton.
The OnQ modules appear to be incompatible with both Leviton and Channelvision can. They can be made it work, but you have to drill some new holes.
In the end i have OnQ, Channel Vision, Leviton and ELK stuff all hapilly in my Leviton can....but the poor can does have some extra holes now...
For newbies i woudl suggest getting a Channelvision can for the most flexibility. Even if the OnQ stuff doesnt fit immediatly from what i can tell you would only need to enlarge some of the holes in the Channel vision can whereas in the Leviton can completely new holes needed to be drilled.
Drilling the new holes is really easy, but is definetely best done when nothing is mounted. I found out late and had to drill holes when most of my can was already filled. This mean little metal chips flying around all the ELK expander boards, OnQ board, etc. Ofcourse i switches everything of and put a rag over the other board...and then blow air through the hole thing when finished..but still it's a bit concerning...
My concern with the OP's question was the depth of the module which appear to be very deep.
Edited by MavRic, 24 April 2009 - 07:23 PM.
#6 Monk
Monk
    Dedicated Cocooner
  • 740 posts
  • Experience:average
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Russound
  • CCTV:ip
  • Phone:OBi100/110
Posted 24 April 2009 - 11:08 PM
I use magnets I take out of old hard drives to help catch the flying metal bits. Stick four magnets .5 inch around your new hole and voila! It really helps...
edit: I don't know to much about magnets, but the ones they put in hard drives are THE strongest magnets I have ever experienced... You need a screwdriver to pry them off.
#7 guba807
guba807
    Cocooner
  • Registered
  • PipPip
  • 17 posts
Posted 27 April 2009 - 08:12 AM
Try coating the drill bit with vaseline. I use this on the car when drilling near carburetor intakes or spark plug holes. The bits of metal will stick to the vaseline. Just remember to use a low speed drill.
#8 Neurorad
Neurorad
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2592 posts
  • Experience:novice
  • Tech:RadioRA2
  • Audio:Nuvo
Posted 28 April 2009 - 01:23 PM
Tony at SetNetPro.com told me Leviton modules are not 'compatible' with ChannelVision enclosures, but it's a simple matter of drilling.
Another reason to extend the wall depth - drilling.
#9 royalj7
royalj7
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 382 posts
Posted 29 April 2009 - 07:03 AM
Strange. I have a 38" CV can and a ton of Leviton modules sitting in there no problem, no modifications needed. I'll post a pic when I get back home.
--Jamie
#10 MavRic
MavRic
    Cocoonut
  • 1164 posts
Posted 29 April 2009 - 08:16 AM
It's the opposite...Channevision MODULES are not compatible with Leviton ENCLOSURES. I haven't tested the other way, but it looks like it should be no problem as confirmed by royalj7 above.
If you want a general purpose can and don't have specific plans for a lot of OnQ/GreyFox stuff i woudl think a channelvision can is your best and most flexible solution.
#11 Steve
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3764 posts
  • Experience:guru
  • Software:CQC
  • Hardware:HAI OmniPro II
  • Tech:UPB, ZigBee, CentraLite
  • Audio:Nuvo
  • Video:SageTV
  • CCTV:ip
Posted 29 April 2009 - 09:09 AM
I prefer CV as well, especially because they have a 50" and we know SWC's are like hard drives and you should buy the biggest you can because they fill up quicker than you would think. I do believe most Leviton modules will fit a CV can as is, but some will require some very minor modification.
#12 Neurorad
Neurorad
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2592 posts
  • Experience:novice
  • Tech:RadioRA2
  • Audio:Nuvo
Posted 29 April 2009 - 11:05 AM
Good to hear about the Leviton modules - my CV 50" just arrived from Tony (clearance, open box, on special this month, included cover, $90 shipped :) ).
Edited by Neurorad, 29 April 2009 - 11:06 AM.
