I've developed the logic and user-interface for two objects, SmartDoor and SmartGarageDoor, for my HA system. The objects are described below and suit my current requirements. However, I'd appreciate ideas from Cocooners about what they'd like to see in a "smart" door-control system.
SmartGarageDoor's Specifications
Inputs/Outputs
- Door Sensor (Input: Senses Open/Closed)
- Door Toggler (Output: Pulsed output to trigger door to open/close.)
- Door State Indicator
Displays door's name and state ("Front Door Closed").
Background is green when door is closed and red when door is open. - Status Indicator
Displays time of door state ("Opened: 4/18/8:00 PM"). Also displays command status ("Closing ...") and error messages ("ERROR: Garage Door failed to close.") - Control
Single toggle button used for opening/closing. Button face displays the appropriate unique command ("Open" or "Close").
- Requests to open/close are timed. If the door fails to respond within the allocated time period, the command is automatically re-issued (Status Indicator displays "Failed to respond. Trying again.").
- If it fails a second time, an error message is displayed in the Status Indicator and an event is logged (can be used to send email).
- While the door is transitioning from one state to another (i.e. open to close), the control button is ignored.
SmartDoor's Specifications
Inputs/Outputs
- Lock Sensor (Input: Senses Locked/Unlocked)
- Lock Opener (Output: Pulsed output to trigger lock to open.)
- Lock Closer (Output: Pulsed output to trigger lock to close.)
Same as SmartGarageDoor. - Lock State Indicator
Padlock icon.
Locked: Closed, green padlock.
Unlocked: Open, red padlock. - Status Indicator
Same as SmartGarageDoor plus displays the lock state ("Locked: 4/18/2009 8:02 PM"). - Control
Same as SmartGarageDoor except button face indicates "Lock" or "Unlock".
Same as SmartGarageDoor plus it denies attempts to operate the lock while the door is open.
Both objects also have Annunciator ("Front Door Open") and Reminder ("Front Door Left Open") functions that can be constrained to operate with a time period or a temperature range.
What else would be useful?
Edited by 123, 18 April 2009 - 09:04 PM.
