123
This is a response to a post in another thread ... that has strayed far, far away from the thread's original question.
The drop-down lists you see in Premise Browser are based on the standard HTML SELECT tag. It uses the OnChange event attribute and therein lies the answer: On Change. If the drop-down list's current selection is VideoIn2, selecting VideoIn2 again represents no change, so the OnChange event is not triggered ... and nothing happens.
By selecting VideoIn1 and then switching back to VideoIn2 it will trigger the OnChange event and the appropriate IR commands will be transmitted.
The solution for you might be to eliminate the drop-list and add custom buttons, one for each video input.
Short answer: No.The problem is my TV has one way communication with Premise. So if someone manually changes it to video3, I need to be able to force premise to resend the video2 command. Right now, you have to select a different source in the GUI, then go back to video2. I was wanting to just simply reselect video2 from the GUI drop down and have it resend video2.
