Elk M1 send email through gmail or comcast?
#1
Posted 13 August 2009 - 05:55 PM
#2
Posted 13 August 2009 - 05:59 PM
So what is the status on sending email through SSL ports? can it be done? I cant get gmail to work. I then tried comcast which uses port 587 and I cant get it to work either? how are you guys sending emails?
You have to use something like stunnel. The ELK doesn't support encrypted (SSL) email.
Edited by wuench, 13 August 2009 - 06:12 PM.
#3
Posted 13 August 2009 - 07:10 PM
#4
Posted 13 August 2009 - 08:24 PM
#5
Posted 13 August 2009 - 08:26 PM
I don't know what you're running stunnel on, but if it's a unix box of some sort, you can just configure postfix as a local relay. This is what I do.
#6
Posted 13 August 2009 - 08:33 PM
[codebox]client = yes
[ssmtp]
accept = 10.xxx.yyy.zzz:465
connect = smtp.gmail.com:465[/codebox]
then the mail client uses 10.xxx.yyy.zzz as the smtp server
#7
Posted 13 August 2009 - 08:53 PM
I didn't think stunnel would work with email. I haven't tried it. But typically the initial connection is plaintext, and then SSL/TLS is negotiated after the client queries the SMTP server for its capabilities. Unless stunnel makes a special provision for SMTP, I doubt it will work.
It works fine. I use it with my Elk. SSL doesn't care what is carried through it. You have it backwards, SSL is negotiated first, then once a tunnel is established the protocol running over it is negotiated.
I would make sure you have a windows firewall entry for the port you setup in stunnel, that would be the first thing to check. Next you might want to check your antivirus, or any other security software to see if it is scanning your email. A lot of these products proxy your SMTP, so when you send mail from your PC you actually send to your antivirus and it forwards to you provider. Sitting in the middle it can scan your mail, and it could interfere. So disable any of those temporarily to rule them out.
As for troubleshooting after that, let's say you have port 5000 setup in stunnel to forward to gmail port 465
<ELK> ---> 5000 <PC> ---> 465 smtp.gmail.com
1.) Make sure stunnel is running and answering requests. Do a netstat -a and you should see an entry for the port you setup 5000 with a status of LISTENING.
2.) From the PC running stunnel, open a command prompt and telnet localhost 5000. You should get a flashing cursor or even better a response from the gmail server.
3.) From another PC telnet to port 5000 (telnet <address> 5000) and you should at least get a flashing cursor. If you get a "could not connect message..." then it is probably a firewall issue on the PC running stunnel.
3.) Next test the gmail connection with telnet. telnet smtp.gmail.com 465 from the PC running stunnel. If that's not working then something is blocking your PC getting out, could be your router, could be you can't resolve the DNS name smtp.gmail.com. Could be an issue in the internet or your service provider.
So run through those and tell us how far you get. If all those are working for you then it is most likely something with your Elk configuration.
Edited by wuench, 13 August 2009 - 08:58 PM.
#8
Posted 13 August 2009 - 09:07 PM
So given that the M1XEP already has the SSL code onboard already, I concur that there is very little reason to not support SSL email natively.
#9
Posted 13 August 2009 - 09:08 PM
pmail.com
http://pmail.com/m32_472.htm
Brian
#10
Posted 13 August 2009 - 09:48 PM
From stunnel.org:
The Stunnel source code is not a complete product -- you still require a functioning SSL library such as OpenSSL or SSLeay in order to compile stunnel. This means that stunnel can support whatever (and only) that which your SSL library can, without making any changes in the Stunnel code.
I'm stuck way back at getting stunnel working on a PC on my LAN.
I will keep reading before I download a thing!
The only thing that seems very clear to me is that getting the XEP to send me emails/SMS via email would be much easier if it supported SSL directly.
#11
Posted 13 August 2009 - 10:27 PM
#12
Posted 13 August 2009 - 11:48 PM
Other considerations are a server based email forwarding that can handle SSL.
Since we can already implement this solution via our own servers, for security reasons I don't see value in Elk Products pursuing this solution. Being tied to a subscription service which provides concentrated targets for hackers and is subject to others' security policies is one factor that disqualified Control4 for me.
#13
Posted 14 August 2009 - 12:07 PM
SSL is *not* negotiated first in the case of port 25 or 587.
#14
Posted 14 August 2009 - 12:20 PM
I think we'll just have to agree to disagree. It's not pertinent to the O.P.'s issues with stunnel anyway.
#15
Posted 14 August 2009 - 12:23 PM
Wow I've got a lot to learn.
From stunnel.org:The Stunnel source code is not a complete product -- you still require a functioning SSL library such as OpenSSL or SSLeay in order to compile stunnel. This means that stunnel can support whatever (and only) that which your SSL library can, without making any changes in the Stunnel code.
I'm in the same boat as you. I don't know enough about all the network protocols to get this working either. I have stunnel installed and running (as far as I can tell), but that does seem to only be part of the equation. I'm going to try the tests Wunch suggested and see where that gets me.
But if anyone is away of a step by step "How To for Dummies" I'd love to see it.
