Jump to content
Mrspeed's Home Automation Project
  • Please log in to reply
23 replies to this topic
#1 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 02 December 2009 - 08:40 AM
House was built in 1990, there is currently no smart wires on the house. I purchased and plan on installing the following;
1- HAI OmniPro II
2- CQC
3- Planning on running 5 or 6 cat6 cables to each room
4- Planning on running 2 RG6 cables to each room
5- On the living room I will run enough 12 gauge speaker cable for 5.1 surround
"Note to self, that is allot of cable for living room, how in the heck am I going to get a box to fit them all"
6- I will install motion detectors and Temperature sensors in all the main areas to include bedrooms.
7- Do have currently have dvr with 7 cameras installed will probably some how tie that into my automation.
8- Install the Monoprice speakers to 10 zones "did not receive them yet"
I have not decided yet on the whole house audio system. Still considering Nuvo and russound
I have not decided what video matrix I will purchase, I need one for a total of 8 tv's I think component will be fine, HDMI would be cool but depends on the price difference.
I will post pictures as I go!
#2 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 January 2010 - 11:11 PM
As promised pictures, most of the stuff to be installed! Is there a way to upload multiple pics? It is only allowing me to do one at time.
#3 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 January 2010 - 11:12 PM
Laundry closet will be copnverted to house all the automation equipment and cables.
#4 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 January 2010 - 11:14 PM
My first drop, 5 cat 6, two rg6 and Eight 12-Gauge audio cables.
Edited by MrSpeed, 05 January 2010 - 11:14 PM.
#5 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 January 2010 - 11:16 PM
My first 3 way HAI UPB switch installed!
#6 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 21 January 2010 - 09:45 AM
Things are moving along, I made a big mistake with my cat 6 cable. I ran stranded instead of solid, I should be getting the solid today or tomorrow and replace the cat6 that I ran. Included are some pics of my progress, please excuse the mess as we are still under construction :o Also this is my first wiring job so I am sure it will not look professional. My HAI panel is wired in and fully operational!
Edited by MrSpeed, 21 January 2010 - 09:45 AM.
#7 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 21 January 2010 - 09:59 AM
Picture of where my media devices will be mounted. It is not the ideal rack, but unfortunately due to the limited space in the closet and the fact that there is still a sink in it, I had to improvise. I would have liked to install a nice rack that mounts on the wall such as this one;
http://www.newegg.co...9-020-_-Product
But that particular unit does not have enough space for Two Satellite receivers, One surround sound denon, one blu ray, 2 xbox 360, WII and probably a Nuvo and a matrix switcher. So for now this rack will have to do.
#8 Neurorad
Neurorad
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1983 posts
  • Experience:novice
  • Tech:RadioRA2
  • Audio:Nuvo
Posted 21 January 2010 - 01:15 PM
Wow, Speed, you are FLYING, strong work!
For additional low voltage drops, it will probably be easier for you to use a low-voltage old work ring, rather than a high voltage junction box. I'm guessing you used that blue box because of the need for 4 gang - I think you can use 2 double gang rangs next to each other. Or, you could cut the back off the blue junction box (with your Dremel - I have the same gray case :o). A little easier to manage the cable slack ('service loops') with an open back.
#9 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 22 January 2010 - 12:15 PM
For additional low voltage drops, it will probably be easier for you to use a low-voltage old work ring, rather than a high voltage junction box. I'm guessing you used that blue box because of the need for 4 gang - I think you can use 2 double gang rangs next to each other. Or, you could cut the back off the blue junction box (with your Dremel - I have the same gray case :)). A little easier to manage the cable slack ('service loops') with an open back.
Thanks for the advice and compliment, I used that box because I needed at least three gangs for the surround sound plus all the other cables. I got my new cable today. SO I will probably be pulling out stuff today and tomorrow and replacing it. Hoping to start using my rack next week!!! I still have to put a server together for cqc and the media. Will probably order that today!
#10 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 25 January 2010 - 03:06 PM
What a task, finished re-wiring the house. Removed the cat6 stranded and replaced with cat6 solid core. Installed the patch panel, will post some pictures in the next day or two after I reconnect the cables to patch panel. Things are looking good! I was able to watch some movies on two of my Samsungs from the mybookworld to the tv's using the DNLA!!!! Also added some 15A HAI switches to control the fans.
#11 10Seconds
10Seconds
    Cocooner
  • Registered
  • PipPip
  • 26 posts
Posted 04 February 2010 - 06:28 PM
So to add the HAI switches are you just cutting out hole in the sheetrock to fit the switch and screwing them into the sheetrock on top and bottom? Or are you going to install a cut-in box?
#12 mustangcoupe
mustangcoupe
    Cocoonut
  • -=Gold Supporter=-
  • 1371 posts
  • Experience:guru
  • Software:Elve
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 05 February 2010 - 08:05 AM
Looks like there could be a metal box in there.
#13 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 February 2010 - 09:58 AM
I am using the existing boxes for the switches, I did add boxes for all my cat6 lines, i will post some pics later of the end result.
#14 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 February 2010 - 10:06 AM
Thjings are moving along, excuse the mess, I did not clean the wire etc yet ;)
#15 MrSpeed
MrSpeed
    Cocooner
  • Registered
  • PipPip
  • 81 posts
Posted 05 February 2010 - 10:07 AM
Thermostat installed
Edited by MrSpeed, 05 February 2010 - 10:08 AM.
