Quixote_1
Hi everyone,
I've seen valves that can shut off the water supply of a home in case of emergency and I am familiar with electronic sprinkler valves for irrigation systems, but can anyone one suggest some sort of valves that may be used to electronically control the flow of water to a shower or bath? I would like to be able to partially open or close the valves using RS-232 if possible, or even a variable voltage rather than being stuck with an all or none arrangement. That way I could use temperature sensors and adjust the hot and cold water taps to achieve a certain temperature at the touch of a button.
I've spent a fair amount of time searching, but have come up empty. Any suggestions or leads would be much appreciated. Working on W.A.F. and I think that if I pull this off in the new shower I will be good for a while.
