Trying to get started Insteon or Z wave?
#1
Posted 08 December 2010 - 04:39 PM
I am looking to put in new lighting in my office where my computer is and I want to be able to control that lighting from my computer. I am researching and found z wave and recently stumbled on insteon, but the question is which way do I go?
I'm now in a whole new world, and searching home automation on youtube is making my head spin.
I do computer support for a living, so don't mind technology and learning new things at all.
That said, which direction should I move towards to make my whole house accessible from the internet, such that I can see what rooms have motion, make lights turn on and off on schedule, control my living room lighting from my harmony remote so I can hit movie mode and have the light auto dim and everything setup to movie mode etc?
Please help me get started in the right direction. I don't want to buy, sell re buy, and keep wasting money so trying to do this right. One thing I also saw on youtube that I LOVED was the guy talked said:
Guy: Computer
Computer: Yes
Guy: Play rock music
Computer; Ok, and rock music started playing.
I was thinking above could be accomplished by finding some wireless microphones that would shoot a signal to usb dongle in computer, then run from audio out on computer to my receiver, but am all ears and eager to learn
Thank you in advance.
#2
Posted 08 December 2010 - 04:45 PM
search any forum and read about insteon and the company that makes it
#3
Posted 08 December 2010 - 06:27 PM
The text to speech you listed is exactly what I use with HomeSeer. There's a good thread on the HomeSeer message board about wirless mics but I never had any luck with these so I use my phone line to issue commands. Works good via the phone.
#4
Posted 08 December 2010 - 08:00 PM
Read the forums and form your own opinion of Insteon, Zwave, UPB etc.
#5
Posted 08 December 2010 - 08:49 PM
One thing you need to consider is whether or not you have the white neutral wire at each switch or dimmer location. If you don't, the only protocol of the 3 discussed that doesn't require a neutral is Z-wave. Both Insteon and UPB do require a neutral.
Don't be lulled into thinking that because your home is reasonably new (assuming it is), that it would be up to date with a neutral everywhere. What happens is that some electricians simply run a loop from the ceiling fixture down to the switch box with only the black hot wire going down and back up, leaving no neutral in the box. This meets code in most jurisdictions, but sure doesn't help us with home automation.
#6
Posted 08 December 2010 - 09:49 PM
If you only are planning a small installation, I think zwave would be good and simple and reliable with just a few devices.
In a large setup I would look at UPB or Insteon. A large setup requires a good controller and the ISY made by Universal devices is awesome, especially if you have some programming experience. At present it only works with Insteon but UPB support is comming.
Insteon will be less expensive than UPB by about half. They also have a larger array of products. UPB is less sensitive to power line noise. Insteon has the new dual band stuff which is probably going to be more reliable than anything else but the cost is almost up to UPB prices.
Tests by IndyMike on power consumption of the newest version of Insteon would indicate that it consumes, by far, the least amount of standby power of anything, something like .25 watts.
Insteon will directly hook up to x10 if you have any of that or want to use some of it. If you want to add some automation that isn't critical and want to do it on the cheap, x10 is the answer. I use lots of x10 stuff mixed in with my Insteon for Christmas and it works nicely.
#7
Posted 09 December 2010 - 07:40 AM
Deane Johnson's point about neutrals is good. Neutrals are not required by NEC code, even today (I understand there is a proposed change in work to require neutral, but it is yet to be approved).
Given my initial impressions from your post, however, I suspect office lighting will be just a start for you. Once you get into it, your automation system will grow to most of the house. Consider likely growth as you choose your protocol and components.
#8
Posted 09 December 2010 - 01:13 PM
I was also an early Z-Wave user. Some of the early hardware had reliability problems. I bought into the Vizia-RF line when it was first introduced and have been happy ever since, no failures. HomeSeer is a little expensive but it works well with most Z-Wave devices. Z-Wave will either work well or not, It won't decide to take a reliability dump when you are a few thousand dollars into a gradual upgrade. I have read of people with multistory houses having problems so approach any non-wired technology with a little caution. In my location Z-Wave works well and is about 99.9% reliable. A drawback to the type of devices that I have is that they are 2-wire (no neutral required). They draw operating power through the load so just any CFL will not work (mine recommend incandescent lights). I have found some CFLs that they are happy with. I believe that you can now purchase 3-wire Z-Wave switches. Just something else to be aware of. My 1950s house is all 2-wire so I did not need to jump through any hoops on the wiring.
I could go on but a lot of this is already spread around on various message boards, and it can get boring.
Good luck.
ken
#9
Posted 09 December 2010 - 01:47 PM
Just for clarification, if my house wiring (built 1980) has a white, black, and ground wire I should be ok right?
Furthermore, Vizia is a good line? I was actually looking at the vizia switches
I was an early INSTEON user and developer. I came away with some low opinions about anything associated with that name. Things may be different now. If you search around on INSTEON plug-in filters, you will start to uncover a whole new aspect of that power-line technology. They have a mix of RF/Power-line devices now so the communication reliability may be better for those devices. The end result is that you 'might' have a 100% reliable system, until your dryer turns on, or you plug in a new printer. Then you have to buy some filter modules and hunt around for the offending device to connect it/them to.
Good luck.
ken
#10
Posted 09 December 2010 - 02:05 PM
Edited by BLH, 09 December 2010 - 02:06 PM.
#11
Posted 09 December 2010 - 02:06 PM
Also where is best place to buy z wave stuff? zwaveproducts.com?
If you only have a Black and a White and both are connected to one terminal of the original switch. You have a switch loop and no neutral in the switch box. Basically the line from the fixture is one of the wires to the switch and the other is back to the fixtures load terminal.
#12
Posted 09 December 2010 - 03:25 PM
Would this allow z wave to work? I don't want to waste money if I can avoid it.
One of the places you might want to compare prices and service with is a CocoonTech sponsor:
http://www.automatedoutlet.com/
Prices seem about as good as anyone has, and the personal service is pretty good from what I hear. My own limited experience with them was very positive. I bought several UPB dimmers, went to install them, and discovered I didn't have a neutral and that UPB needed one. Nobody had told me this previously. They promptly issued a return authorization.
There are probably other places to consider, I just don't happen to know who they are.
BTW, the Leviton Vizia RF+ switches are probably the most reliable around. One thing to know about is that they aren't a rocker paddle. You push on the bottom only. It's a click on, click off switch or dimmer. Some like this, some don't.
On the issue of a white and black wire in the box, you're right. The presence of the white wire may simply mean it's being used to loop down from the fixture. I have a Vizia RF+ dimmer operating on one right now. However, I would certainly like to see someone with more Z-wave experience answer your question on the switches working on the loop circuits. Just an abundance of caution.
#13
Posted 09 December 2010 - 03:30 PM
#14
Posted 10 December 2010 - 12:45 AM
#15
Posted 10 December 2010 - 06:43 AM
They have kits with an Insteon fixture mounted module and a Insteon SwitchLinc. With it you again wire the line and neutral to the existing wires in the switch box to power the SwitchLinc and then it controls the fixture module. I tried one and in my older homes very small fixture boxes. The module didn't fit.
