For those with an Elk WSV, how did you connect the green(status) and black(ground) wires to your system? I followed the install guide by connecting the WSV's ground to an Elk Supervised Power Supply (P212S) and the green wire to an input expander on Z16. What I'm getting is strange, my status on the device reads:Status=Violated State=Open Volts= 13.8. This doesn't change when the valve is open or closed. I also have a resistor on the green wire at the Zone Expander but it's not showing EOL under State. Should I connect the WSV's ground to the Zone Expander instead of the Supervised Power Supply? Does the Zone Expander require a ground for a zone?
