ELK M1XEP major troubles - no longer responding
#1
Posted 03 January 2011 - 09:34 PM
I had no issues connecting up the M1XEP to the system and have been using it for nearly two weeks.
I recently purchased the Ekeypad Pro iPhone app and was beginning to customize the M1 to make use of Ekeypad Pro. At first no problems but then I attempted to configure the M1XEP to send emails. After a few pushes of changes which resulted in reboots, the unit stopped responding.
For the life of me, I cannot get it back. I am fairly computer savvy but could not even get basic pings.
I have followed the nice documents that describe troubleshooting procedures without any luck. I am able to install the jumper and verify that it switches between DHCP and static IP. DHCP does not connect to my router and obtain an IP address.
My last test I switched the M1XEP to it's default static IP of 192.168.0.251 (installed jumper and verified double flashes) and configure a laptop with IP 192.168.0.100. I then connected a BRAND NEW crossover cable between them to eliminate cable and routers issues. Sometimes I can get ping responses, even consistantly but if I try to access the M1XEP using ELKRP or even the M1XEP diagnostics utility, the M1XEP stops responding and I can no longer even ping it. The green ethernet activity light stays on constantly along with the yellow/orange ethernet connectivity light.
I did not do any firmware upgrades on eith the M1 Gold panel or the M1XEP.
Is the M1XEP toast? If so, any logical reason for it to be so? I understand that this thing is difficult to work with for configuring email but it should not have killed it right?
If it's toast, does ELK offer any repair/replacement for these units if it's not under warranty?
Thanks for any help or insite you can offer!
#2
Posted 04 January 2011 - 03:44 AM
Also make sure your wiring is good - especially between the XEP And the board; who knows - maybe the thing locks up when it can't talk to the panel...
#3
Posted 04 January 2011 - 07:38 AM
#4
Posted 04 January 2011 - 11:02 AM
#5
Posted 04 January 2011 - 05:38 PM
I can see the network activity for about 30 seconds and then the orange power light blinks and network goes dead for a few seconds. About 1 minute later the process starts again.
The unit is out of warranty so I am on my own.
Is it possible to connect directly to the M1XEP via serial connection and perhaps reflash the code?
I thought the only way to flash it was through the network?
#6
Posted 05 January 2011 - 09:59 AM
Has anyone had any experience doing this through the serial port?
#7
Posted 05 January 2011 - 03:48 PM
Everything I read about flashing one of these devices seems to indicate that it can only be done through the ethernet port.
If you can "see" the M1XEP from the enrollment screen in the ELK RP2 software, can't you update the firmware from there?
#8
Posted 05 January 2011 - 09:03 PM
#9
Posted 20 January 2011 - 10:44 AM
Thanks for the help!
#10
Posted 26 February 2012 - 05:50 PM
#11
Posted 26 February 2012 - 08:44 PM
#12
Posted 27 February 2012 - 01:55 AM
How can I find the firmware version and is this something I can update?
Edited by sanders2222, 27 February 2012 - 02:04 AM.
#13
Posted 27 February 2012 - 06:54 AM
#14
Posted 27 February 2012 - 09:18 AM
Edited by wuench, 27 February 2012 - 09:19 AM.
#15
Posted 27 February 2012 - 08:07 PM
After all this, I put things back to the DHCP mode. The RP could find the XEP, but when I try to connect, a message usually pops up the connection was terminated (retry/Cancel). When I cancel, the RP console says I'm connected. However, if I try to send or receive, I get the message the connection has been terminated. The XEP reboots every few minutes and I have no idea why. Sounds defective to me. It worked just fine the first time I powered up out of the box. But somehow it's fallen into a reboot loop I cannot stop.
