I know...I should be doing searches, but I know it will turn up thousands of posts.
I want to be able to control the lights in my shop from my home (about 150' away).
Existing equipment...Elk M1G with M1XEP in my home, CQC on a PC in my home, a HA can with an Elk datahub in my shop, and a LAN switch in my shop (same LAN as my home). I don't have any available wires between home and shop, and don't want to pull any. The shop walls are "open" (stud walls with no drywall on them), so I can pull lots of wires in the shop if necessary. Shop and home are on same utility power. Shop has a load center to supply it, and power for the home "goes thru" that load center.
The shop has eight flourescent fixtures (4', two bulbs each), all controlled by a pair of three-way switches. I want to keep the functionality of the three-way switches, and also be able to turn the lites on/off from my home, either from an Elk keypad or from my CQC PC. The real goal is have a PTZ IP camera inside my shop, and be able to use it at night from my home by turning on the shop lights from my home first.
I don't have any other lighting controls in my setup, and don't really expect to add much more in the future.
Suggestions?
Ira
Suggestions?
Ira
