I spent the day swapping out my OMNI II for a new OPII. Very straightforward procedure. On initial power-up I only had the console connected and it repeatedly beeped as expected. At the console I am getting "no controller data". I can "4/up arrow" to ensure the console is set as console 1 and the other 3 settings are OK. No other buttons work.
I rechecked my wiring and the console is connected as described (same way as OMNI II). I pulled the console and toned out the 4 wires. No issues there.
I can connect to the panel via serial but not IP since the console is required for that set up.
So I figure that either my console went bad during the change (seems highly unlikely), I have a bad panel or something else needs to be done prior to power-up.
Would appreciate any comments and suggestions or ideas for further testing. My next step is to reinstall the OMNI II and see if it will communicate with the console.
Thanks in advance.
Rick
EDIT:
I ran the console self-test and it appears that the console failed during the swap-over. After connecting the console to a 9 volt battery and running the test the console would only display a full screen of question marks. For whatever reason, disconnecting the console from the OMNI II and reattaching to the OPII seems to have killed my console. Go figure.
Thanks in advance.
Rick
EDIT:
