New wifi device. Looks promising
#1
Posted 22 November 2011 - 04:20 PM
#2
Posted 25 November 2011 - 05:45 PM
#3
Posted 26 November 2011 - 01:39 AM
#4
Posted 01 January 2012 - 01:29 PM
I saw this on dvice today. Did you get yours yet?I don't know. I will have to wait till the one I ordered shows up so I can see what all it does.
http://dvice.com/arc...ne-the-tiny.php
#5
Posted 01 January 2012 - 05:29 PM
#6
Posted 02 January 2012 - 07:52 AM
Along a similiar trend is what is going on these days with Arduino "stuff" for that DIY person.
http://www.instructa...duino-Projects/
I guess then I wouldn't mind testing the device if it also had a built in NIC and more control of the software running on it. For the "beginner" in this realm the use of Twitter, email, or text messaging to get data from the device would be optimal; those seasoned HA/DIY folks would want other means to get data from the device or the option of said means not limited to just what is available.
#7
Posted 03 January 2012 - 06:50 PM
They don't get delivered till around March. I just ordered one to play with, but they are way to expensive to actually use.
With my home automation system I am able to send commands via email, so this device will work with my system. Did i mention that the twine is way to expensive???
#8
Posted 03 January 2012 - 07:48 PM
#9
Posted 04 January 2012 - 03:00 AM
I've found some temperature sensors for 2.2cents each, yep you read it right. how can home automation still be expensive, its bogling my mind. So DIY is the way to go for me. Can you guys point me at some wholesale supplier sites for PIR sensors and other types of sensors. thanks. I also started a new thread with some of my research.
#10
Posted 04 January 2012 - 06:00 PM
Dimension: 3.2cm x 2.4cm x 2.8cm (approx)
Infrared sensor with control circuit board
The sensitivity and holding time can be adjusted
Working Voltage Range: DC 4.5V- 20V
Current drain:<60uA
Voltage Output: High/Low level signal:3.3V TTL output
Detection distance: 3--7M(can be adjusted)
Detection range: <140°
Delay time: 5-200S(can be adjusted, default 5s +-3%)
Blockade time: 2.5 S (default)
Trigger: L: Non-repeatable trigger H: Repeat Trigger (default)
Work temperature:-20-+80°C
Trigger Method: L unrepeatable trigger / H repeatable trigger
#11
Posted 04 January 2012 - 09:42 PM
#12
Posted 02 February 2012 - 05:54 PM
Just FYI.
Yes a bare Temp.sensor may be 2.2. cents only.
And this device is much more expensive.
But it looks like a rather complete system
#13
Posted 13 April 2012 - 07:54 AM
#14
Posted 13 April 2012 - 03:13 PM
Edited by freedom, 13 April 2012 - 03:13 PM.
