Premise Browser very slow from networked PCs
#1
Posted 04 December 2011 - 02:45 PM
I have a dedicated PC for premise. When I access the premise browser from the local pc it works great (from localhost or from the computer's dns name) if i try to access it from any other networked pc, it takes literally 2 hours to load. the screen immediately gets the "Premise Browser" in the title bar of internet explorer and resizes the window, but then it sits and waits. After the 2 hour wait period, it loads and works fine.
I have both manually registered and let IE load the Activex and it didn't seem to help. I even put the Premise PC address into "Trusted sites" and lowered the security to low. Still takes 2 hours.
Anyone have any ideas?
#2
Posted 04 December 2011 - 06:11 PM
I've never experienced this problem with Premise Browser so I don't have a ready solution for you.
I doubt the ActiveX plugin is to blame. If the required ActiveX is not loaded on the networked PC, the home-page loads anyway, lickety-split, and is followed by a pop-up indicating the PC's browser needs the ActiveX. However you can test this theory by trying Premise's MiniBrowser which runs without any plugins. Just point the networked PC's browser to your Premise Server using http://YourPremiseServerIP/ppc. BTW, you might want to check if the PPC site is available before making any conclusions about the test. Using Builder, go to WebServer> Sites>Default Web Site> Roots> PPC. If there's no PPC use whatever else you find there (MB, XB, etc).
BTW, I assume your Premise Server is using port 80 rather than its alternate (port 86)? It seems like some sort of bandwidth-throttling is in effect but I have no idea what would be responsible for strangling port 80.
Just a thought, if the PC running Premise has an alternate web-server (like Win XP Pro) you can disable the Premise service and then fire up the alternate web-server. Assuming the alternate web-server has a home page of some sort, try accessing it from a networked PC and compare the performance. It might shed some light on the source of the throttling.
Edited by 123, 04 December 2011 - 06:12 PM.
#3
Posted 04 December 2011 - 09:27 PM
Win XP has an alternate web server? Like one built in? Please enlighten me, or are you talking about a 3rd party.
#4
Posted 04 December 2011 - 09:34 PM
#5
Posted 04 December 2011 - 11:13 PM
#6
Posted 05 December 2011 - 01:40 AM
If you hit the ppc (ip address:port/ppc), does it still hang? If so, it's not the ActiveX issue.
What is your Premise server running? I'm assuming default installation?
#7
Posted 05 December 2011 - 08:01 AM
- Open XP's Services application and stop the 'Premise SYS Server' and 'Premise SYS Monitor' services. For this test, we don't want Premise to be active.
- Double-click each of the two Premise services and change their 'Startup Type' from 'Automatic' to 'Manual'. For this test, we don't want Premise's services to automatically restart after a reboot.
- Open XP's Control Panel and select 'Add or Remove Programs'.
- Select 'Add or Remove Windows Components'.
- Enable 'Internet Information Services'.
- Click Next and wait for IIS to be installed (the PC may need to be rebooted).
If you re-enable the Premise services with IIS installed, Premise will detect that port 80 is in use (by IIS) and will use port 86. To access Premise Browser, you'll need to append the port number to the URL as follows: http://YourPremiseServerIP:86
Edited by 123, 05 December 2011 - 08:14 AM.
#8
Posted 06 December 2011 - 10:34 PM
#9
Posted 06 December 2011 - 11:44 PM
Thanks everyone for your help.
