I use an Elk M1G, CQC, and an ISY99i. Last night, I decided to upgrade to the latest ISY release and add their Elk module. The ISY module has firmware prerequisites of M1G 5.2.8 and M1XEP 1.3.28. My versions were older, so I upgraded, set everything up, and at first glance, all seemed good.
While checking things in CQC, I noticed that the M1G connection went offline, then came online. I then noticed that $LostCommRes was higher, and as I watched things, the connection kept going offline and coming back online.
Much troubleshooting ensued including sniffing the traffic from the M1G to both CQC and the ISY. I discovered that, once a minute, the M1G is sending the RP (remote programming mode entered) code, and then 10 seconds later, it sends the IE programming mode exited code. 50 seconds later, at the top of the next minute, here comes RP again, and then 10 seconds later, IE again.
This behavior remains the same whether just CQC is connected, just the ISY, or both.
I have two rules that run in the M1G once a minute, so just in case it could be rule related, I made a copy of my Elk configuration, deleted all rules in the copy, and sent that to the control. The behavior remained exactly the same.
FWIW, during the ten second interval, the M1XEP web interface also becomes non-responsive, although it doesn't display the "Panel has entered programming mode" message that appears when running ElkRP.
I have no idea where to look next to figure out the potential source of the problem. I also remember seeing a note that said bad things happen if you downgrade M1G firmware, so going backwards doesn't seem viable.
Anyone have ideas of where I might try troubleshooting next?
Chris
Chris
