PIM no signal (SPIM-01 UPB GEN II)
#1
Posted 18 December 2011 - 02:52 PM
The first I need to say is Im new in this world of automation and my english is not very good.
Now my problem;
I have a PIM (SPIM-01 UPB GEN II) and I havent any signal between it and the switch (PCS RWS) they're in the same panel. In Upstart I see a noise medium, but the signal is missing (no number). I tried to connect with the swicht and I can't. The switch is like a 50 m from the PIM.
Thank you
#2
Posted 18 December 2011 - 06:16 PM
Here in the U.S. we have split phase 110VAC.
It is really a 220VAC line split in two.
So half of a house is on one leg and the other half on the other leg.
Which is why we need a phase coupler to make sure the UPB signals can get from one leg to another.
Noise medium is not a great sign, you may have too much noise to see the signals.
I would try to take the switch out and wire it to a plug in cord.
Cap off all the unused wirs and the output wire. You only need the black, white and ground wires connected to test.
Then plug both the cord and PIM into the same power strip.
Thsi way you know they are on the same electrical path.
If it works like this, then you knwo you have a noise or transmission problem.
If it doesn;t work, then you know one of the modules (switch or PIM) are bad.
#3
Posted 19 December 2011 - 12:53 AM
Thank you for the response. I live in Barbados, we have 110v. I using 2 amplifier connected near to the PIM, I think the noise for that but i dont have more option, Im going to try to speak with the electrician and do that test. Tomorrow I tell you.
#4
Posted 19 December 2011 - 02:18 AM
That may be your noise source.
Also, I think you have two legs of 110V like we do here in the U.S., which means you need a phase coupler.
I am betting the switch and the PIM are on separate phases.
Edited by Desert_AIP, 19 December 2011 - 12:55 PM.
#5
Posted 19 December 2011 - 06:46 AM
Here I added a UPB repeater in addition to the coupler. Not sure though what repeater would do with noise on the wire.
#6
Posted 20 December 2011 - 12:00 AM
I tried to connect in the same phase, but still not working. Tomorrow Im going to try to make a little circuit to try it and Ill tell you.
Thank you.!
#7
Posted 20 December 2011 - 09:26 PM
Don't know what to do... I was reading this forum for a week now. So many good thoughs here, but nothing is works for me. One day i even disconnected the wire, that comes to breaker from master bathroom, and connected it to another breaker with different phase and wasn' t able to find any dimmer from second group (not from laundry room nor from master bathroom) while first group was discoverable all the time from almost any receptacle.
Edited by nmconcept, 20 December 2011 - 09:30 PM.
#8
Posted 21 December 2011 - 12:51 PM
I don't test already the "close circuit" maybe this weekend. Ill tell you about the progress.
Thank you!
#9
Posted 21 December 2011 - 01:40 PM
Sounds like you have something noisy on the second phase of your electrical system.
CFL bulbs or motors (fans, etc.) are the usual culprits.
The best way to isolate the noise source is to monitor the noise level in UPStart and then systematically disconnect things until the noise disappears.
Then you'll need to add a noise filter to that piece of equipment or replace the noisy bulb.
#10
Posted 21 December 2011 - 05:04 PM
Edited by nmconcept, 22 December 2011 - 01:31 AM.
#11
Posted 21 December 2011 - 05:07 PM
#12
Posted 21 December 2011 - 05:36 PM
Looks like something weird inside the can.
Also
Have you mapped out your switches by phase?
On the individual switch pages it will show which phase each resides on.
#13
Posted 22 December 2011 - 01:29 AM
Yes, it is grounded to metal structured wiring box while it is grounded to studs and receptacle. And i don't think that this may cause any troubles with communication. Omni board communicates trough PIM via serial port and PIM is electrically isolated from controller, i mean it has optoelectronic couples inside to isolate powerline from sensitive controller.Do you have the Omni properly grounded?
I don't know what else to do to make it work. I'll check ground one more time for any case.
No i didn't. I never thought about this.Also
In upstart NetCommTest file i noticed column 'Phase' and it is shows 'S'. Will check it tomorrow morning.
Thank you for advice, Desert_AIP
Edited by nmconcept, 22 December 2011 - 01:29 AM.
#14
Posted 22 December 2011 - 01:40 AM
#15
Posted 22 December 2011 - 07:39 PM
