I'm trying to monitor a doorbell press using an ELK-930 via the elkm1 control perl library.
According to the ELK M1 manual setting the zone definition for the Door Bell zone to 16 (non-alarm) won't work (and it doesn't) as no activity is logged. The other option was setting the definition to 13 (Aux1 24Hr. Alarm). This works and I can capture the event but the problem with this is that the alarm is not reset which, according to the manual, it should be as it "resets upon restoral". The siren and keypad are not affected but I have a rule which is "WHENEVER EVERY 10 SECONDS AND ANY ALARM, ANY AREA IS ACTIVE" and this rule fires until I disarm the system which resets the Aux1 24Hr Alarm.
Is there any way to create a rule while using the non-alarm definition which will force the M1 to log the event to signal the elkm1 control library?
Otherwise, is it possible to stop the alarm when using the Aux1 24Hr Alarm definition without disarming the entire system (obviously this would be less then ideal on a doorbell press!).
Thanks for your help.
