Jump to content
Haiku and HughesNet, satellite based internet service...
  • Please log in to reply
3 replies to this topic
#1 AnthonyZ
AnthonyZ
    Dedicated Cocooner
  • -=Gold Supporter=-
  • 662 posts
  • Experience:guru
  • Software:CQC
  • Hardware:HAI OmniPro II, Custom
  • Tech:UPB, ZigBee, Custom
  • CCTV:analog, ip, dvr
Posted 25 January 2012 - 06:27 PM
I have a client with a second home that is fairly deep in the mountains. They are stuck with HughesNet's (lousy) service. We are able to use SnapLink and PC Access to log in to the controller remotely (if slowly) but, Haiku won't connect. It's as if it times out before it can negotiate the connection. Of course, I look like the bad guy 'cause the client bought a $50 app that won't work. I just wonder if there is any way to force a longer attempt at connecting or if there are any other suggestions for getting it to work.
#2 lupinglade
lupinglade
    Cocoonut
  • Manufacturers
  • PipPipPipPip
  • 1514 posts
  • Experience:guru
  • Software:Custom
  • Tech:UPB, INSTEON, Z-Wave, ZigBee, Custom
  • Audio:Nuvo
  • Video:AirPlay
  • CCTV:ip, dvr
  • Phone:Asterisk
Posted 25 January 2012 - 06:41 PM
The timeout is 30 seconds I believe, that should be sufficient to initiate a valid connection in most cases. I would guess the problem is something else. Have you verified all the parameters entered into Haiku are 100% correct? Such as the address and port, as well as the private key parts of course.
A common error is users entering http:// into the address field, but it should not be entered.
Another known issue is that HAIs controllers can get "stuck" sometimes and not accept new connections, I doubt this is the problem here though if you are testing via SnapLink from the same device (specifically). The fix for this is simply to restart the controller (power cycle). It usually happens when a lot of connects/disconnects happen in a short period of time and is probably some sort of a firmware bug.
You can also PM me the connection details and I can do some tests to check what might be the problem.
Edited by lupinglade, 25 January 2012 - 06:42 PM.
#3 AnthonyZ
AnthonyZ
    Dedicated Cocooner
  • 662 posts
  • Experience:guru
  • Software:CQC
Posted 26 January 2012 - 11:44 AM
PM sent...
#4 lupinglade
lupinglade
    Cocoonut
  • Manufacturers
  • PipPipPipPip
  • 1514 posts
  • Experience:guru
  • Software:Custom
  • Audio:Nuvo
  • Video:AirPlay
  • CCTV:ip, dvr
  • Phone:Asterisk
Posted 26 January 2012 - 11:48 AM
Reply sent ;)
