We are currently finishing up a garage build on a new property. Plan is to build the house next. In the meantime currently installing an Elk-M1 temporarily in the garage, once the house is built we will relocate the M1 to the house hoping for minimal wiring (hopefully databus only) from the house to the garage. The distance between the 2 buildings is approx 150'.
The M1 is in its own box with only the essentials for communication and battery backup. All expansion cards required for the garage security and automation are in a separate box along with required aux. power supply which will stay in the garage.
The one area I'm having an issue with is the temperature sensors (M1ZTS) which require connection to the M1 inputs 1-16. Looking for possible alternatives in this area, is 1-wire the only other option here other than wiring the temp sensors to the M1 relocated to the house.
Edited by sbwright, 21 June 2012 - 03:28 PM.
