The good news, I had an Acronis backup image of the main drive. The bad news, it was over a year old.
I managed to restore the disk and found about 200 Windows updates were needed. I performed these updates as well as an update to Java's latest version seven.
Here are were the problems began.
I had to reinstall the SageTV software (I have the exe files backed up as you can't get those anymore) but could not get the service started. Turns out a couple of problems existed with the Java update.
One: It did not install correctly from the update notification icon. I had to uninstall the current version, then manually download the update from Java's site (java.com).
Second: After scouring the SageTV forum I found that the MSVCR100.dll file located in the c:\Program Files\Java\jre7\bin directory had to be manually copied into the c:\Windows directory!
I thought I would post this as an FYI in hopes it would save someone rebuilding their SageTV server from some frustrating time trying to figure out why their service would not start.
I also had to perform this file copy on the PC clients.
Another note is that Microsoft stopped supporting updates to their XP software (I believe anything without the second service pack), so make sure you have a backup image of at least your hard drive containing your operating system! I would recommend updating your software if running XP now, then creating an image of that drive.
I believe you can download service packs on the Internet if your current XP system needs them.
Another strategy would be just to backup what you currently have working and just leave it at that.
