I purchased the GRI 110WG-12 surface mount wide gap contacts for use on my exterior sliding doors. I thought I needed the wide gap contacts since I have a 1" trim piece between the wired portion of the contact and the contact magnet. After I installed the first contact magnet I am able to open the sliding door close to 6" before the ELK recognizes the open contact. I did not realize the wide gap was this 'wide'.
So I'm thinking I will move the magnet 3" horizontally from the wired end of the contact simply to reduce the 'alarm gap' to 2"-3".
Does this make sense?
Mounting Surface Wide-Gap Contacts
Started by
sbex55
, Aug 28 2012 02:42 PM
3 replies to this topic
#1
Posted 28 August 2012 - 02:42 PM
#2
Posted 28 August 2012 - 02:51 PM
Make sure you look at the spec sheet. it should tell you the tolerance. I have some garage door contacts that have to be mounted within a certain distance (min and max). If you are too close, it does not work.
#3
Posted 28 August 2012 - 03:15 PM
Contacts don't cost that much - why not get one better suited for your application?
#4
Posted 28 August 2012 - 05:49 PM
6" sounds like it's excessive even for WG units, but I've seen stranger things.
