HAI omni pro II - sporatic 3 beeps from console
I have almost the same thing. Maybe about once a week, always the same console, nothing ever in the logs. I've replaced the console and the connector but it still does it.
Ano, when was the last time you did a eeprom or ram reset? My console would make a 'scratching' noise instead of the 'beeps' ...once the eeprom reset was done, no more problems. Might be worth a try.
We just experienced this problem today. The system is running the latest firmware (4.0b).
Was there any resolution to what is causing this to happen?
I sold the house. That fixed it.  :unsure:
Check the connector that connects to the console. HAI had a bad batch of these, so might be a problem.  They are a fairly standard connector.
Had the same problem, removed my HAI Wireless receiver and the problem went away. I only had one sensor attached to it and found a workaround.  I am not sure if the issue is a failing HAI receiver or perhaps too much current was being drawn? I find the latter not likely since I've had this running for a couple of years before the problem developed.
