OMNI link II API polling frequency
btrvalik
If I write a piece of code using the Omnilink protocol / SDK, how often can I poll the system without causing a high system load / cause a problem?
Can I read the logfile every minute?
Should the session be left connected for an extended period of time, or should it be torn down and re-established or each query, or perhaps reestablished once per hour / day?
Look at the SDK example code to enable unsolicited notifications. With these enabled you don't need to poll as the controller will push events in real time as they occur. I am leaving the session connected 24/7. I remember reading somewhere there is a 30 session limit, but I can't find the documentation right now.
Thanks for the pointer, I did not see that when I first looked .. that is exactly what I want. Do you know if this is supported with the 3.0 ROM? I'll likely upgrade it at some point in the near future..
A couple of tips that might help
- There is a 20 session limit for TCP. Right now Omni-Link 2 only uses TCP so it is limited to 20 sessions. I would advise not using all 20 though. It's good practice to leave some open for reconnects, etc.
- You can leave a session open for as long as you'd like, but you need to send the controller a message at least once every 5 minutes, or it will close the socket
- Omni-Link 2 was added in 2.16 I believe, but you really should upgrade to a much newer firmware, since we have added more notifications since 3.0
- I wouldn't tear down the connection unless you are done with it, since there is some overhead in securing the session.
Aaron
