Jump to content
Email notifier board
  • Please log in to reply
264 replies to this topic
#256 StarTrekDoors
StarTrekDoors
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 203 posts
Posted 05 January 2019 - 08:31 PM
Merry Xmas to all. Hope everyone is enjoying the holidays
Spent way too much of my day in my HA world, but I cannot cannot get my new Notifier board to work.  Using FW v4.0B, Notifier v2.0, PC Access Dealer v3.17.  I believe the board is working as the Ethernet lights flash, and it is auto adjusting the time, but I'm out of ideas on how to get it to send a test message.  Any suggestions?  Tried  gmail, comcast. and yahoo email addresses.
Geoff
Email Notifier, when it works, does not work with any email provider using advanced security.
The workaround is to use a Cellular Gateway, Leviton's Unsecured Cloud Email, or your own email server.  BTW - If you simply want to use the Email Notifier, even if you use a local email server or cellular gateway, the email notifier does not send messages for every event intended.  It is simply less than reliable but some messages may be better than none.
If you read through the many pages of this topic, you'll find network issues can account for additional failures, so if you do use a work-around solution, the device may also go offline.
#257 pete_c
    Cocoonut
  • -=Gold Supporter=-
  • 9402 posts
  • Experience:average
  • Audio:Russound
  • Video:MythTV
  • CCTV:analog, ip, dvr
Posted 07 January 2019 - 08:24 AM
@Geoff,
Tell us about your OmniPro 2 system and what it is you want to do with it?
I did notice a software update to PCA a couple days ago.
So a quickie list of what you have:
1 - OmniPro 2 panel - is this an OP2 that is chip upgradable or software upgradable
2 - What additions to you have to your base panel?  (zone, output, audio and email board?)
3 - are you utilizing an Alarm company monitoring
4 - do you utilize Leviton Snaplink on your mobile phone and what is the OS on your mobile phone
5 - what serial ports are you using on the panel and what are you using them for?
5 - I understand too that you are also using Homeseer 3 and the Omni Plugin.
Note that the Leviton notifier board does work for some and not for others.
The notifier board is very primitive in design using the serial bus and a network connection.
Upgrading the firmware is done via the serial port (very slow).
You can do email, text notifications, time sync much faster using OmniPanel software addendums like where as the only software that works to manage your OP2 panel is PC Access whether it is connected serially or via the network.
BTW here on Cocoontech many folks are using the Elk or the Omni Pro panel and have DIY'd their systems either with new contruction or post contruction.  In DIY mode many folks have learned much about what the combo panels can do and what they cannot do.
Some of the users here of the Elk / OmniPro 2 panel only utilize the panels for security / basic automation and nothing else.  While others here utilize software addedums to their panels (smart phone consoles, touchscreens or automation software).
You can take your old Omni Pro panel today to current use with current automation widgets like Homeseer, CQC, Smartthings, Alexa, Google voice et al.  There is also now plenty of OpenSource automation which will talk to your OmniPro 2 panel.  (two mentioned here is OpenHab and and Home Assistant).  Nowadays you can mix Windows and Linux and iOS software or just Windows or just Linux or iOS.  It really all depends on what you are most comfortable with.  Many Smartphone users want to manage all of their automation via their smartphone.  Some via tablets and today some via new AI stuff like Alexa, GV or Cortana.  It all really depends on what you want to do with your panel.
#258 bighorn
bighorn
    Cocooner
  • Registered
  • PipPip
  • 62 posts
  • Tech:UPB
  • Audio:Russound
  • Video:AirPlay
  • CCTV:analog, dvr
  • Phone:POTS, VoIP via ISP
Posted 09 January 2019 - 08:28 PM
Pete,
Good questions. See responses below.
Geoff,
Here OP2 with HAI HLC UPB switches, Russound E Series, Compoint Intercom, Somfy blinds, and analogue cctv cameras. Recently added Alexa Dot and still evaluating HomeSeer PC software. Also using HomeKit with Myro:Home Helper as I decide if should I go with Amazon or Apple AI UI. Initial interest getting basic notifications (arm/disarm, alerts etc). Used to use Haiku Helper but looking for new system.
Thanks, Ill update it.
Chip upgrade.
Zone expander and emailer board.
Installed iOS apps: Haiku, Space, Snaplink and Myro:Home. Liked haiku best.
3 serial ports: HAI UPB, Leviton email notifier, Russound
Yes still in my 30 day trial on a PC install. So far just using OMNI plug in.
Really disappointed with notifier email options.
Im using v2.0. Is there a newer version.
I need to look into another reliable option.
Always looking for cool new ideas. Right now priority is SA UPB switches in garage and Alexa vs HomeKit voice evaualtuons.
Thanks for sharing all of your wisdom.
Edited by bighorn, 31 January 2019 - 05:01 PM.
#259 pete_c
    Cocoonut
  • 9402 posts
  • Audio:Russound
  • Video:MythTV
Posted 10 January 2019 - 08:23 AM
Well you have the Email board already installed and there are users here on the forum that use it fine.
Do you have the email board working at this time?
Are you using any Omnitouch screens?  IP or Serial?
Relating to HAI CCTV went to a sort of hybrid of the old and the new as I upgraded my cameras to IP HD.
The newest OP2 firmware talks fine to streaming IPHD cameras doing MJPEG or stills in rapid sucession.
For the chipped OP2 boards the last 4.X revision was the last one for said boards.
The newer OP2 panels have more serial ports and you can update firmware via ethernet / serial connections.
Baby steps....
#260 bighorn
bighorn
    Cocooner
  • Registered
  • PipPip
  • 62 posts
  • Tech:UPB
  • Audio:Russound
  • Video:AirPlay
  • CCTV:analog, dvr
Posted 14 January 2019 - 10:59 AM
HI Pete,
I changed the Notifier to from smtp2go to Leviton cloud and it seems to be working perfectly now.  Can receive email and text messages to Verizon.
My OP2 requires chipped FW upgrades.  Wonder why Leviton won't support chipped FW beyond current v4.0B? I used to think that only having 3 serial ports was a limitation but now with software like HomeSeer it doesn't seem to be an issue.
Thanks for your help and encouragement!
Geoff
#261 BirdingPix
BirdingPix
    Cocooner
  • Registered
  • PipPip
  • 13 posts
Posted 31 January 2019 - 02:14 PM
Pete,
My OmniNotifier is acting up and not sending out any emails now for the past week.  I've re-loaded all the settings, still using Leviton Cloud (which has worked fine last couple of years)... still no emails get sent.  Frustrating.   I am not sure if the Leviton Cloud is down... or is the problem on my end?  Everything looks correct per PC Access...
So then I noticed your message (see below) and you mention OTHER methods to get the OP2 to send out emails per events.
How and with what?
THANKS
Dave
#262 BirdingPix
BirdingPix
    Cocooner
  • Registered
  • PipPip
  • 13 posts
Posted 31 January 2019 - 02:51 PM
I've read some more... and now I see that OpenHAB 2 can connect to HAI OP2.
So that is a new path for me and I'm going to read/learn about OpenHAB 2 on RaspberryPi and see if I can get it all to connect to my OP2.
OpenHAB 2 looks like it can do a ton of neat stuff.
best,
Dave
#263 ano
ano
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3476 posts
  • Experience:guru
  • Tech:UPB, ZigBee
  • Audio:HAI
  • Phone:Ooma
Posted 31 January 2019 - 05:33 PM
best,
Dave
I might suggest to also look at Home Assistant. https://www.home-assistant.io/
I haven't used either Home Assistant or OpenHab, but I read that HA might be a bit better supported.
#264 pete_c
    Cocoonut
  • 9402 posts
  • Audio:Russound
  • Video:MythTV
Posted 31 January 2019 - 05:49 PM
@Geoff,
Good news!
Wonder why Leviton won't support chipped FW beyond current v4.0B? Probably cuz the board is old maybe?
Here utilize all of the serial ports and X10 port on my OmniPro 2 panel with the upgradable firmware piece to it and duplicate x10, UPB, ZWave and ZWave Homeseer connections and have the Homeseer Omni Plugin running on two HS3 computers. (IE many network connections to the OP2 panel).
#265 pete_c
    Cocoonut
  • 9402 posts
  • Audio:Russound
  • Video:MythTV
Posted 31 January 2019 - 05:57 PM
How and with what?
Software like CQC, Homeseer, Home Assistant, OmnilinkBridge or OpenHab (and more).
Here been using STunnel for years and it works fine with whatever email I utilize on the automation boxes.
A bit biased about using Homeseer as I have used the software since Homeseer 1 introduced around 1998 (ran it on Windows 95/98 at the time) (and afterwards used Homeseer 2 and currently using Homeseer 3).
If you want notifications toot sweet for free ( tout de suite) install Ryan's OmniLinkBridge plug in.  There are discussions here relating to its use.
You can run the OmniLinkBridge on Windows or Linux (with Mono). Here run it in a Linux Docker container.
Here running the OmniLinkBridge, Home Assistant and Node red initially on an RPi2.
The GiHub is here ==> OmniLinkBridge
Roots for this application is Ryan's HAILogger which just logged stuff from the Omni panel, did time sync and send emails..and was posted as a time sync application when the OmniPro promiscuous ethernet port debacle started to occur on the OmniPro panels.
Today it talks to a Samsung Hub or MQTT (and whatever automation software that talks MQTT like Home Asistant or Homeseer or ...)
You can disable the Hub and MQTT stuff if you want and just configure the plugin to sent alert email messages.
