I think I'd have no problems in at least attempting to expand it HA capabilities on my own. I've been lurking around these forums for a bit, in attempting to get some info to try this. I also have no problem in having someone (for instance a paid 'consultant') remotely program/set-up things.
Here's the current state of the system:
A) security/fire: (functioning)
-hard-wired doors/windows (w/ the exception of one wireless one), split into 12 zones
-2 wired motion detectors
-2-wire smokes
B) automation: (not really working)
-3 UPB switches
I think part of the problem is that the installer was techinically really good at security part, but may be not so much at the HA part? Anyway, there is also a solar PV system in the house, so may be that is interfering with the power line signals. Of course, the reason I selected the Elk to begin with was to do at least 'some' HA stuff, and expand from there, so it's been a little disappointing (hence the reason for me branching out on my own to learn more about the system). I even bought the Home Controls UPB System Design book, but it's somewhat beyond me. I briefly perused Elk's webinars. Some directions I think could work:
-switching over from UPB to Z-wave (for several switches/outlets). This should avoid any solar PV interference issues. I'm thinking some of the Leviton stuff.
-also, adding two Z-wave thermostats (the Nest and new Honeywell wifi models look nice, but having rules hooking the t-stat in to the overall system sounds compelling). I don't think installing wired thermostats are practical in my case.
I did play around w/ ElkRP2 and wrote up a few rules for the garage door (I added a wireless GE sensor, since a Elk/GE transceiver was part of the install). It's been a while since that part was online, so not sure if the non-SSL email is working still (it's getting harder to find those services). I don't have the keypad installer code, but assume that a factory reset (?) might get me that functionality if needed.
Anyway, that's where it at. At this point, any help is much appreciated. Thanks.
kv
