I need to get wiring access to Input 1 for counter/frequency data massaging. This will be used for an anemometer that puts out dry contact pulses. While this seems fairly easy I need some input on the hardware to use.
Looking at the board I see I probably need
- 16 pin ribbon cable with 16 pin DIL header male connector on both ends,
- 16 pin breakout board for above with wire terminals.
Some questions.
- CAI board pictures seem to show non-standard pinout labelling to others 87654321 vs. 13579...
am I reading this wrong?
are they hardware compatible with label translation?
- Can somebody direct me to a good source for these. (I really only want terminals on the end of a cable that plugs into CAI WC)
Some questions.
