Ah, the nightmare of that DL-900 software (BSR shakes in his chair remembering those days trying to initially connect to his Caddx NX8-e with this POS software by GE :nutz: )!
I dug up these old notes that I had. You have to use the keypad to change these settings. Also, these notes are for version 2.06 so not sure if they would work with your system.
Location 207, Serial Port Enabled (Home Automation Enabled)
Location 208, Serial Port Baud Rate (defaults to 9600, but needs to match your software setting)
Location 209, Home Automation Protocol, Binary
Location 210, Transition Based Broadcasts, All segments off
Command/Request enables, Options listed below must be on. All other options are optional...
Location 211
- Segment 1, options 2, 5, 6, & 7 ON
- Segment 2, option 1 ON
- Segment 3, Options 1 & 2 ON
- Segment 4, Options 6, 7, & 8 ON
When you run the DL-900 software go to Program>>Setup>>Direct Connect (using 586)
Make sure you hit the * key or whatever it is that 'saves' the settings (I remember messing this up, better check those segments to make sure they took).
I also sort of remember that ASCII will work with Location 209, but just not sure (or that you had to change to ASCII to get the HomeSeer software to work).
Make sure NOTHING else is using the serial port (I.E. no other software is running). I sort of remember even having to reboot after disabling HomeSeer.
If this does indeed work, you must sing BSR's praises in this thread
ray: (just kidding, but if you do have problems, please let us know and maybe something in my memory will toggle).
Good luck!
