Doing some planning. Have a door that will have a reed switch and also will have a door strike. Have to use the M1KAM access module.
Wondering if I can use the one reed switch which would be wired in parallel going to a zone input on the M1 and also the door open sense input on the KAM?
I assume that both inputs are high impedance and should work fine.
When the M1 is armed away the reed would be used monitor the door and activate an alarm should the door be forced open. When M1 is in disarmed mode it will monitor door status on the KAM.
The M1 and KAM are going to be mounted in the same 28" housing so cabling the reed to both inputs will be a breeze.
Can not see any catch in doing this but thought it worth floating it past you guys.
Regards,
Fleetz
Regards,
Fleetz
