Got a real head scratcher!
Configuring another M1 for a job at the moment and engineering what I can ahead of installation. Built up a simple telephone line, Mode 3 (RJ31X) and line out module and started testing the system, everything seems fine.....except.
Now here is the kicker. I have configured the M1 in RP local and remote telephone control in Globals G01-G05 = 2, setup a telephone user (me) for now, reporting format =5.
I have always configured the M1 in this setup configuration and when the M1 goes into alarm it rings the number fine. This one won't.....I have checked the configuration of previous jobs and confirm the setup up is the same. I never have had to program rules to ring the nominated number on alarm before. If I program up the rule with whenever the system is in alarm then ring the number in Telephone 1.....it works fine.
I can phone in remotely and control the M1 fine.
I can hit "***" and seize the line fine. I can engage the speaker with "*0*". So Mode 3 (RJ31X) is working fine.I have checked and double checked the Mode 3 connection and it is fine, it has to be to have the functionality stated above.
Running 5.2.10 firmware and using RP 2.0.20.
Has anyone else noticed a change in how the M1 seizes the line in alarm condition? I checked the last few projects where I am using reporting format 5 under the Telephone user and then check there were no rules associated to facilitate seizing the line and calling out and there are none.
Any thoughts?
Regards,
Fleetz
Any thoughts?
Regards,
Fleetz
