Recommendation for serial controlled FM tuner
My Nuvo dual zone tuner just died for the second time.  Before I get ready to ship it off to Nuvo (again) I was wondering if anyone has a recommendation for a serial controlled FM tuner that I might replace it with?  I only need one zone.  Thanks.
pete_c said:
You can DIY one if you want or purchase a second Nuvu Tuner used on Ebay?
Time to Rock
Just be sure to use a 3.3v Arduino. The standard ones are 5v. You could use a voltage divider, but using the right Arduino would be simpler. Sparkfun is a very reliable company that makes very reliable PCB breakouts. With this solution you could even customize the commands.
