Frunple
I have two programs that run fine on their own. I'd like to combine them and run them both on one Arduino but I can't figure it out.
The first one displays the status of my blinds, I shortened it to one blind for posting here.
int z1w1switchstate;
z1w1reading = digitalRead(z1w1Pin);
// If the switch changed, due to bounce or pressing...
if (z1w1reading != z1w1previous)
// reset the debouncing timer
time = millis();
if ((millis() - time) > debounce)
// whatever the switch is at, its been there for a long time
// so lets settle on it!
z1w1switchstate = z1w1reading;
// Now invert the output
if (z1w1switchstate == HIGH)
z1w1State = LOW;
else
z1w1State = HIGH;
// print the results to the serial monitor:
if (z1w1State != lastz1w1State)
if (z1w1State == HIGH)
Serial.print("Z1W11\r\n" );
else
Serial.print("Z1W10\r\n" );
digitalWrite(z1w1Outpin, z1w1State);
// Save the last reading so we keep a running tally
z1w1previous = z1w1reading;
lastz1w1State = z1w1State;
The second is something I just started to play with. It pings my phone ip to determine when I'm home.
#include <SPI.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02 }; // mac address for ethernet shield
byte ip[] = {10,12,8,60}; // ip address for ethernet shield
IPAddress pingAddr(10,12,8,26); // ip address to ping
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
void setup()
// start Ethernet
Ethernet.begin(mac, ip);
Serial.begin(9600);
void loop()
ICMPEchoReply echoReply = ping(pingAddr, 4);
if (echoReply.status == SUCCESS)
Serial.print("Scott\r\n");
startfresh();
else
delay(1000);
void startfresh()
delay(300000);
startfresh();
else
loop();
They both then interface with Elve to do what I want.
The problem is the delays. They shut down all operations for the full delay.
What I've come up with so far is below, it I call the pingme() function I lock out of the loop(), I know this but I just pasted it in for place holding for now.
#include <SPI.h>
char buffer [256];
int z1w1Pin = A0; // the number of the input pin
int z1w1Outpin = 22; // the number of the output pin
int z1w1State = LOW; // the current state of the output pin
int lastz1w1State; // the previous state of the output pin
int z1w1reading; // the current reading from the input pin
int z1w1previous = HIGH; // the previous reading from the input pin
// the follow variables are long's because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long time = 0; // the last time the output pin was toggled
long debounce = 50; // the debounce time, increase if the output flickers
void setup()
pinMode(z1w1Pin, INPUT_PULLUP);
pinMode(z1w1Outpin, OUTPUT);
Serial.begin(9600);
void loop()
time = millis();
z1w1State = LOW;
else
z1w1State = HIGH;
else
void pingme()
startfresh();
else
delay(1000);
void startfresh()
delay(300000);
startfresh();
else
loop();
Any help is appreciated... it's all new to me!
time = millis();
z1w1State = LOW;
else
z1w1State = HIGH;
else
#include <SPI.h>
char buffer [256];
void setup()
// start Ethernet
Serial.begin(9600);
void loop()
startfresh();
else
delay(1000);
void startfresh()
delay(300000);
startfresh();
else
loop();
#include <SPI.h>
char buffer [256];
void setup()
Serial.begin(9600);
void loop()
time = millis();
z1w1State = LOW;
else
z1w1State = HIGH;
else
void pingme()
startfresh();
else
delay(1000);
void startfresh()
delay(300000);
startfresh();
else
loop();
