Haiku Space CHANGELOG
Status
Not open for further replies.
Space 1.01
- Fixes iBeacon major/minor matching not working
- Fixed a potential crash when attempting to change an audio source
- Fixed a potential hang when the user interface text size is set to Large in iOS
- Fixed an issue where audio sources were watched for metadata when it was not needed
- Fixed an issue that could prevent some cameras from working if they were loaded from the controller's Extended Setup
- Fixed access controls not showing correct status color
- Fixed some issues with editing iBeacon triggers
- Note: You may need to set the camera number to 0 on Axis cameras if they were loaded from Extended Setup using Space 1.0
Space 1.02
- Removed duplciate Foscam entry in camera list
Space 1.05
- Added ability to control a primary security area from the home screen
- Added labels under home screen icons
- Added room # of units ON display in Rooms section
- Added mode to thermostat display
- Added option to turn off perimeter beeps in Settings
- Added ability to set Stream # for camera servers
- Added ability to change camera # for cameras defined in Space
- Added support for Vivotek cameras
- The Space configuration file can now be copied/backed up via iTunes File Access
- Fixed compatibility with many RTSP cameras (switched to TCP streaming)
- Stability improvements
- Improved JPEG camera support
- Improved camera video quality on some cameras
- Fixes crash when viewing a room that contains a User Setting item
- Fixed thermostat color potentially not being changed after heating/cooling is done
- Graphical tweaks
How long does it take for the update to post to the App Store? After almost 18 hours 1.05 is still not showing up.
The first time I launched version 1.05 I was brought to the controller screen with the address field cleared. After entering the address again it connected. Strange that this would happen when upgrading from 1.04. Thanks for adding the words and security status to the home screen. I had gone back to using Haiku, but am going to give Space another shot.
iBeacon and Space Automation ERRORS
All iBeacons failed to interface with Space Automation w/1.05
iBeacons work with RADBeacon App and Beacon App
Operation Failed
Unexpected error during operation (status=5)
OL Request Extended Object Status Operation!
Try refreshing the coordination using home screen menu configuration
iPhone 5s, iOS 8.2
iPad 2, iOS 8.2
Space 1.06
- Fixed iBeacons not working since 1.05
- Fixed a common crash when using the Show Controllers setting
- Fixed a crash when viewing a camera without a URL set
Space 1.07
- Fixed disabled auxiliary sensor low/high setpoints to display correctly
- Renamed lights to units in Room "units on" count
- iOS 8.3 related fixes
Space 1.1
- Added support for Somfy SDN/URTSI shades
- Added emergency actions to Security view
- Added long press gesture emergency menu to Security home page icon
- Added long press gesture All On/Off to Rooms, Control, Audio home page icons
- Added support for dim/brighten on Standard units
- Added section separators in icon lists
- UI tweaks
- Disconnected climate sensors now display N/A instead of really low value
- Auxiliary climate sensors in range/limit status is now more accurate
- Removed "not ready" status bar notices on auxiliary (climate) sensors
- Fixed cameras removed from Extended Setup not being removed from Space until Space is restarted
- Fixed intermittent issues with entering beacon UDIDs/controller private keys
- Fixed a crash when refereshing the events list
Status
