lupinglade
What features do you want to see added to Space?
eddy said:This is a minor thing, but it would improve the "first use" experience if you made it easier to enter the security key.
Typing in the 32-character security key as a "password" and hoping you don't make any mistakes is a pain point. That obfuscation seems totally overkill for a single-use text entry field... (just don't configure Space when somebody is looking over your shoulder... which is likely going to be in the privacy of your own home anyway.)
Similarly, it's impractical to edit the security key from the Settings screen since it's a password. If it were me, I'd just have a "clear security key" button instead of showing ••••••••••••••••••••••••••••••••.
Also, another big UI improvement for entering the security key would be a custom hex keypad (something like this for example) so you don't have to constantly switch between alpha and numeric using the "123" button.
1) You can request a refund from Apple as I mentioned earlier. We have no ability to do this.brianjames said:1) To get a refund since the space app is unusable.
2) To fix the issue I reported in the Haiku app because it does the same thing in Space - http://cocoontech.com/forums/topic/21840-haiku-365-vizia-rf-issue/
3) To be able to have a list view instead of the icon view. If I had a handful of lights it would be ok. It just does not work when you have 70+ lights.
Only using an iBeacon. You would not get the desired accuracy otherwise.fdnyfish said:Is there a way to make the Geographical Area smaller?
What features do you find missing? We've covered just about everything that Haiku had. Although the layout of the status screen is different and that is something we are working on. We also are looking into re-adding Favorites as well as "Units On" count in Rooms.bitNine said:How about you add the literally NUMEROUS features that Haiku had, that Space does not. Start there, then maybe we can ask for more.
