Haiku Ip camera configuration
You can connect to at least the RTSP stream with Space. You will need to use the Generic setting, specify the URL as rtsp://hostname (or ip)
Then set the stream type to RTSP and specify the correct RTSP port.
Im trying everything locally
I am able to connect to only one camera at a time rtsp://192.168.1.231:554
Do I need to change the rtsp port an all 9 of my cameras and port forward them all?
I changed all the RTSP ports on each camera and did port forwarding in my router.  I am unable to see the cameras on the software.
I am able to see each camera while using VLC Media Player (notice the address in the upper left hand corner)
My camera addresses are below, and all show open when I test the rtsp ports on canyouseeme.org
192.168.1.231 (rtsp 2310)
192.168.1.232 (rtsp 2320)
192.168.1.233 (rtsp 2330)
192.168.1.234 (rtsp 2340)
192.168.1.235 (rtsp 2350)
192.168.1.236 (rtsp 2360)
192.168.1.237 (rtsp 2370)
192.168.1.238 (rtsp 2380)
192.168.1.239 (rtsp 2390)
here is the setup screen of my ip cam 192.168.1.235
The fix for this is coming shortly in 1.05. The issue is that we are defaulting to UDP streaming, but should be defaulting to TCP.
Great,
Any way to copy settings to another controller?  or even email a controller setting to someone else.  Maybe an import/export (so I can set everything up for the wife and kids just once on mine and send to them)
fdnyfish said:
Great,
This is coming also.
