I am trying to integrate my HiFi2 system with an OmniPro II with PC Access v3.14.1.760.
First I used the HiFi 2 Setup utility (Ethernet connection) to setup all the Sources and Zones on the HiFi2. Everything works as programmed. The Leviton HiFi2 iPod app works to control the system as well.
I would prefer to use the SnapLink app and PC Access as an integrated system to control everything.
(The OmniPro II, HiFi2 and progamming server are connected to the same network switch)
Using the PC Access Extended Setup/HiFi2/Discover Tool I am able to connect (discover) and accept the IP address of the HiFi2. The problem is that none if its Audio Source/Zone configuration is diplayed or comes accross in PC Access. I assume it would show up under PCAccess Audio Sources/Zones or PCAccess Extended Setup/HiFi2?
I figured the HiFi2 must need to be connected serially as well so...
I connected the serial port of the HiFi2 to Port 2 of the OmniPro II (using the same 6 pin cable as the UPB module to OmniPro) modified the PCAccess Expansion settings for Module 1 - HAI HiFi2, and PCAccess Expansion\Serial Port 2 to HAI HiFi2 to see if this would resolve the issue. No Change.
Could the Cable Pinout be different then the UPB? What am I missing?
I've spent hours looking through HAI HiFi2 and OmniPro II Manuals and blogs and cannot find any detailed setup information for the integration of these 2 together. Any assistance would be greatly appreciated.
