Electrical contractor new to HA
Facing a problem with splitting up combined loads. I have 3 "zones" of lights in the kitchen which were all wired together to a single switch with no way of separating (easily)
Pendants over sink, chandeliers over island & under cabinet lights are presently all controlled by a single switch in the island
I Want to separate into the respective areas for scene control with local dimming capability
I am figuring on tying through the switch legs so that basically everything will now just have a constant 120 volt feed. My question is, what do you recommend?
Looking at either Radio Ra2 multi button keypad with dimming modules at the lights or Leviton HLC multi-button with a Pulseworx dimming module at each area of lights
Can I have dimming capabilities at the HLC, like the Lutron will? Also, looks like the Lutron solution requires Inclusive software to integrate the dimming module into the system
As a side note, I plan on eventually changing out my existing alarm panel to an OmniPro and integrating the home as I go along
