Jump to content
* * * - - 1 votes
IP control of a Samsung TV
  • Please log in to reply
34 replies to this topic
#1 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Experience:average
  • Hardware:HAI OmniPro II, Ocelot, RUC-01
  • Tech:X10-PLC, UPB, ZigBee, Custom
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 09 June 2015 - 03:49 PM
Anyone now where I might find IP commands for a Samsung Smart TV?
It has an app and I can control it from my iPad/iPod Touch and it's well integrated with the web - Youtube link to iPad, etc.
So I know it accepts commands.
I'd like to send HTML commands to it over my internal LAN.
Such as switching to a specific input when a vehicle enters the driveway to display my IP camera, or muting when the phone rings.
I can view the camera manually so I just need to know the commands I need to send to the TV.
#2 BobS0327
BobS0327
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 470 posts
  • Software:Open Source Automation
  • Hardware:Custom
  • Tech:Z-Wave
  • CCTV:analog
  • Phone:Ooma
Posted 09 June 2015 - 10:47 PM
It's my understanding that Samsung will not release the IP protocol to third parties.  That is, it is not an open protocol.  With that said, one possible source of info would be the OpenRemote site  http://www.openremot...msung TV Remote
#3 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 10 June 2015 - 01:18 PM
I'm probably going to have to tinker with it.
I'm thinking of a Raspberry pi interfaced with my Omni Pro
Thanks for the link
#4 damage
damage
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1175 posts
  • Twitter:@doghouselabs
  • Experience:guru
  • Software:Custom
  • Hardware:TimeCommander+, Custom
  • Tech:X10-PLC, X10-RF, UPB, Z-Wave, ZigBee, 1-Wire, xAP, xPL
  • Audio:Squeezebox
  • Video:SageTV
  • CCTV:analog, ip, dvr
  • Phone:Asterisk, Linksys PAP2, OBi100/110
Posted 10 June 2015 - 03:01 PM
the code here is what i used as the base to control my tv & bluray.
#5 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 11 June 2015 - 11:53 AM
I'll take a look, thanks
#6 tadr
tadr
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 181 posts
Posted 11 June 2015 - 01:40 PM
Not being able to turn mine on via IP is a dealbreaker for me, unfortunately.  I really wish more manufacturers would keep the network port active in standby.
#7 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 11 June 2015 - 07:28 PM
I keep my Ocelot around just for IR control.
#8 apalrd
apalrd
    Newbie
  • Registered
  • Pip
  • 4 posts
Posted 12 June 2015 - 10:06 PM
If you have a Raspberry Pi, you can command a TV over the Pi's HDMI port with CEC.
XBMC can do this (although normally it works in the opppsite direction - Using the TV's remote to control XBMC), but it can also turn the TV on and off.
#9 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 13 June 2015 - 01:10 PM
Do you know if the ports are limited?  Command only through port 1 or the ARC port (port 2)?
All HDMI ports are populated, but I could swap the Raspberry Pi in to port 4
#10 apalrd
apalrd
    Newbie
  • Registered
  • Pip
  • 4 posts
Posted 15 June 2015 - 01:33 AM
I don't know why it wouldn't be on all ports. I have a Pannasonic TV with 4 HDMI ports, with the Pi (with XBMC) on port 4 and a Blu-ray player on port 2 which both use CEC to receive commands from the TV's remote. The TV will turn on and tune to the appropriate HDMI port when either of them is turned on for these two devices. The Pi also turns the TV off instead of a screensaver, if it is the active source.
As for automation, I'm not sure if anyone has written code specifically to turn a TV on remotely, but libCEC is open source and XBMC will turn the TV on if it's off and XBMC receives a remote command (e.g. if I open XBMC remote on Android and press a left/right button).
#11 Desert_AIP
Desert_AIP
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1848 posts
  • Audio:HAI
  • CCTV:ip, dvr
  • Phone:POTS
Posted 15 June 2015 - 10:17 AM
Thanks, that makes sense.
You're right, the Blu Ray player, etc. turns on the TV and switches to the correct input.
Essentially I want the driveway sensor to switch over to my IP camera automatically.
I think it should be straight forward but I'm still at my infancy of understanding and programming the Pi.
#12 apalrd
apalrd
    Newbie
  • Registered
  • Pip
  • 4 posts
Posted 15 June 2015 - 12:55 PM
If you have a way to command the TV once it's on, you could use a player program (like XBMC) on the Pi and wake it up (by e.g. sending a menu command via it's web interface). It would then wakeup the TV for you, and you can command the TV via IP.
HDMI CEC is designed for devices to set the path of switches between themself and the TV to their input, although you could spoof an Active Source message to force the TV to switch to a different HDMI port. But there's no way to command a non-HDMI port at all.
Edit: I didn't want to double post so I added more to this one.
I installed libCEC on a raspberry pi (I think this is all of the packages, I could be wrong):
sudo apt-get install libcec2 libcec-dev cec-utils
Then I turned the TV off (I was waching TV on another HDMI input)
echo 'standby 0' | cec-client -s
Then back on again
echo 'on 0' | cec-client -s
The input that was previously active was active again (which is not the input the Pi is on), but for some reason CEC didn't work for it (I couldn't control it with the TV's remote). I turned the TV off then on with the remote and it worked again.
Edited by apalrd, 15 June 2015 - 09:35 PM.
#13 BaduFamily
BaduFamily
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 243 posts
  • Twitter:cazwax
  • Experience:novice
  • Software:Harmony, Custom
  • Hardware:Elk M1, Custom
  • Tech:Custom
  • Audio:Custom
  • Video:AirPlay
  • CCTV:ip
  • Phone:POTS, VoIP via ISP
Posted 17 November 2015 - 12:28 PM
multisystem - I think the OP has a smart Samsung tv already; why else would the question be posted?
given that do you have useful advice on how to use IP to control the Samsung TV you are pitching?
#14 wkearney99
wkearney99
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1537 posts
  • Experience:guru
  • Software:EventGhost, Girder, Mister House, NetRemote
  • Tech:X10-PLC, X10-RF, Z-Wave, ZigBee, RadioRA, RadioRA2, Crestron, xAP, xPL
  • Audio:Russound
  • Video:Windows Media Center
  • CCTV:analog, dvr
  • Phone:Asterisk, Grandstream, Linksys PAP2, OBi100/110, POTS, VoIP via ISP
Posted 20 November 2015 - 11:02 AM
<sigh> I just picked up a 24" samsung for use with a treadmill.  Rather disappointing to discover the lack of proper IP control.  Had I figured that out ahead of time I probably wouldn't have gotten it.  That and it doesn't have a single power button, but uses a d-pad-like joystick on the back.  I'll try waking it up from across the room via IR or the Xbox's Kinect emitter.
#15 drvnbysound
drvnbysound
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2857 posts
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Custom
  • Video:SageTV
Posted 22 November 2015 - 12:19 AM
I bought a Samsung LCD back in 2008... I spent months searching many forums for information about controlling that (and other Samsung TVs). It was due to the lack of control and associated information, that I've since converted to LG. I bought (2) LG models within 24 months of that 2008 purchase, and replaced the one referenced earlier this year with an LG. All LG TV's I've seen since 2008 have a serial port - they used to provide a DB9 connector, now it's via a 3.5mm port. The protocol is open and published - it used to be included in the back of the user manuals. There is also a dedicated site with LOTS of information about it here: http://www.lgrs232.com/
Edited by drvnbysound, 22 November 2015 - 12:20 AM.
