I have an OPII and the requisite RZC0P 3+ interface from an old Elk install, however it's been a good 3-4 years since I've messed with ZWave and am unsure how to integrate the lock to my network. I found a document from Worthington (http://www2.worthingtondistribution.com/downloads/HAI_Z-Wave_Lock_Integration_1-4-2012.pdf) that provides a process, but it recommends using a Leviton USB stick that appears to have fallen from support and doesn't work with any current versions of Windows 8/10.
Can I just update the firmware on the RZC0P and enroll the lock using the OPII, or do I need some sort of installer tool? Could I use this USB stick or must it be the Leviton unit:
http://www.amazon.com/Aeotec-Aeon-Labs-Z-Stick-ZW090-A/dp/B00X0AWA6E/ref=cm_cr_pr_product_top?ie=UTF8
I don't currently have any switches or lights running ZWave (everything is UPB), will that present any problems?
Thanks!
Thanks!
