Jump to content
* * * * * 1 votes
Could we have a wiring section?
  • Please log in to reply
16 replies to this topic
#1 wkearney99
wkearney99
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1322 posts
  • Experience:guru
  • Software:EventGhost, Girder, Mister House, NetRemote
  • Tech:X10-PLC, X10-RF, Z-Wave, ZigBee, RadioRA, RadioRA2, Crestron, xAP, xPL
  • Audio:Russound
  • Video:Windows Media Center
  • CCTV:analog, dvr
  • Phone:Asterisk, Grandstream, Linksys PAP2, OBi100/110, POTS, VoIP via ISP
Posted 30 October 2015 - 09:23 AM
There's the 'Wiring Closet' catch-all, which is a fun idea, but what about one actually for wiring?
Just a thought...
#2 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3332 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 30 October 2015 - 10:09 AM
I wish that a wiring forum existed when I started my installation. Wiring was the area where I had the most to learn. I especially needed help with preparing my vinyl windows for sensors. I messed up drilling the first few holes. I also had a poor connection on the data bus that haunted me for months. I also think that my cabling should be much neater. When I flush mounted my Elk wiring box in the wall I made one puch hole for wires to enter and one for wires to exit and those holes filled up very quickly. Now I wish that I had puched more holes through the box and wall stud but it's a little late for that.
I have experience wiring automotive and small engine equipment which is relatively high powered and the splices are not that critical and I have experience wiring inside transistor radios and such where there is very low current and all spices require solder but this industry is low powered and using mechanical splices and I had some problems with the different types of connectors and splices. I just wasn't used to handling them at first.
I think it's a great idea, Mike.
#3 pete_c
    Cocoonut
  • -=Gold Supporter=-
  • 8827 posts
  • Experience:average
  • Audio:Russound
  • Video:MythTV
  • CCTV:analog, ip, dvr
Posted 30 October 2015 - 11:20 AM
+1
#4 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1086 posts
  • Experience:guru
  • Hardware:ISY-99
  • Tech:INSTEON, 1-Wire
  • Video:XBMC
  • CCTV:ip
  • Phone:Ooma
Posted 30 October 2015 - 05:02 PM
We need to be able to paste items into the forum first.
#5 drvnbysound
drvnbysound
    Cocoonut
  • Registered
  • PipPipPipPip
  • 2857 posts
  • Hardware:Elk M1
  • Tech:Z-Wave
  • Audio:Custom
  • Video:SageTV
Posted 30 October 2015 - 06:45 PM
What are you not able to paste into the forum?
#6 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1086 posts
  • Experience:guru
  • Hardware:ISY-99
  • Video:XBMC
  • CCTV:ip
  • Phone:Ooma
Posted 30 October 2015 - 07:10 PM
Not anything. Not even to quote our text works.
This was raised a year ago to no avail. Most posters give up and go elsewhere.
#7 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3332 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 31 October 2015 - 06:24 AM
Try ctrl-V to paste into forum from the clipboard
#8 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1086 posts
  • Experience:guru
  • Hardware:ISY-99
  • Video:XBMC
  • CCTV:ip
  • Phone:Ooma
Posted 31 October 2015 - 07:00 AM
I know how to use the Windows GUI editing.
I cannot paste into  post except in
this box
Again. this has been reported many times by many people for more than a year.
Editing is also a problem. Backspace can delete the whole post. The forum software was never set up properly. Other forums had the same problems using the same IP Board software until  some options were set properly.
Searching in this forum you should find many examples of people complaining of this but either the admin doesn't care or cannot figure it out.
#9 wkearney99
wkearney99
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1322 posts
  • Experience:guru
  • Audio:Russound
  • CCTV:analog, dvr
Posted 31 October 2015 - 08:02 AM
Look, start your own threads for complaints.  I'm just looking for a forum that lets us group our wiring conversations, not just bitch about what others have provided for us... for free.
#10 pete_c
    Cocoonut
  • 8827 posts
  • Audio:Russound
  • Video:MythTV
Posted 31 October 2015 - 01:12 PM
Yeah here my very first interior door wiring (about 10 years ago) I had best guesstimated the door frame and decided to drill from the basement up to the kitchen.  That said I did drill off a bit and through the kitchen wood floor.  I have since patched it and you really cannot tell these days.  On an exterior door wired a bit too tight and when the door frame changed over time it did pull my soldered wires loose very slowly giving me a bunch of grief.
Here I have multiple attics which I cannot reach easily from main attic so I utilize a fiberglass extention pole that was given to me in the 1990's.  I do not know what it is called these days.
I have seen these types of posts under security and wiring closet but it would be nicer to have a subsection just dedicated to wiring.
#11 LarrylLix
LarrylLix
    Cocoonut
  • Registered
  • PipPipPipPip
  • 1086 posts
  • Experience:guru
  • Hardware:ISY-99
  • Video:XBMC
  • CCTV:ip
  • Phone:Ooma
Posted 31 October 2015 - 07:20 PM
Oh I thought you might have wanted to be able to post diagrams and pictures for actual wiring. Perhaps you are only interested in text discussion instead.
Edited by LarrylLix, 31 October 2015 - 11:04 PM.
#12 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3332 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 01 November 2015 - 08:08 AM
I have no problem posting photos either
#13 pete_c
    Cocoonut
  • 8827 posts
  • Audio:Russound
  • Video:MythTV
Posted 01 November 2015 - 10:00 AM
Here is a logical drawing of my automation from 2009.
There are many blogs / pictures posted relating to many folks low voltage wiring endeavors.
Attached File  HS2-HAI.jpg   155.27K   16 downloads
Here best alarm wiring wasn't done by me rather it was prewiring done by an alarm company / gurus done before windows were finished.  Same with a home build in the 1970's.  IE: getting wire to a window frame isn't difficult but integration to the window can be a PITA relating to a nice look (WAF stuff).
So far I have only seen 3-4 of us interested in a subsection here on the forum for a wiring section.
@Bill maybe trying a poll would help?
Attached File  poll.jpg   139.7K   17 downloads
Relating to this stuff and newbies to automation I think that much of the attraction relating to new automation is using wireless trinkets; well except for the wiring of a wall switch.
#14 DELInstallations
DELInstallations
    Cocoonut
  • Professionals
  • PipPipPipPip
  • 5400 posts
  • Software:Custom
  • Hardware:Custom
  • Tech:ZigBee
  • Audio:Custom
  • Video:Custom
Posted 01 November 2015 - 01:06 PM
I think I'm blocked from seeing anything hosted through the forum. SOme pictures I can see, others I can't .
#15 pete_c
    Cocoonut
  • 8827 posts
  • Audio:Russound
  • Video:MythTV
Posted 01 November 2015 - 02:09 PM
Well if I do a post with linked pictures then you do not have to log in to see the pictures.
If I attach pictures then you do have to log in to see the pictures.
Thinking a paid membership gives you more candy but not sure anymore these days what the candy is.
Most of the home / residential low voltage wiring stuff I have learned from here on Cocoontech and from folks like you Del.
Commercially mostly involved in planning and design of commercial stuff and creation of standards type of stuff a few years back.
