C
chucklyons
Guest
I've been working on some UI stuff - taking W84s and 123's MiniBrowser work, then trying to sync it up with the Automation Browser.
What a learning curve!!
jQuery and jQuery Mobile aka 'JQM'. CSS3. HTML5. Javascript. It required thinking thru the MB structure of W84's work.
AB - How to tailor the AB? Then working with the CSS contained within Themes.
Then trying to merge the two to have same (or similar) functionality. For instance, the MB version pulls the menu items from AB's Global Tasks and populates the MB UI.
I haven't figured out to use the AB CSS to give the AB CSS3 type of effects. Thus square corners for AB vs rounded for MB
Converting 'em' used in the MB CSS to 'px' that the AB understands was time consuming.
Then using breakpoints to change the style of the MB to work better on mobile devices.
And giving you the option from an audio track to play via mSense or via the browser. (Here's looking at you, Sam!)
I still have some work to do for consistency.
Here's some screen shots...MB first, then AB, then MB MobileView attachment 7523View attachment 7524View attachment 7525
