So short of running some type of polling, is there any way of my code finding out that a zone has been bypassed? If there's any event that signifies a change was made to a zone, I could check specifically for that condition and it would accomplish what I need.
I'm trying to run some code when a bypass occurs, and there are several different sources that can initiate the bypass. One of them is Alexa via the Hue emulator via Haiku Helper's HTTP API. Is there a way to run a function in the HH Script from the HH HTTP API (i.e. could I have Hue Emulator run a custom function that I write in the HH Script file)?
If there's no way to do this, will Space Helper have this event in the API? If so, do you have an ETA on Space Helper? And while on the subject... any update on when the next iteration of the Space UI is going to be available? It's been awhile since the last update, but I assume you're still working on the new version... right?
Thanks.
