RogueOne
I was able to enroll all 3 of my elk wireless sensors and also my GE sensors. Couple problems. I couldn't figure out a way to enroll the GE sensors from ELKRP and had to use the keypad. When I checked ELK RP the new ge sensors were in a hardwired zone instead of a wireless zone. Also the enrolment was a bit messed up, for example I enrolled my ge back door on the keypad for zone 35 and when I labeled zone 35 as back door in elkrp the keypad recognized it as my motion. so I changed everything to match.
The other issue is I am not sure which definitions to use in elkrp configuration. For example my door sensor I selected option 1 (burglar entry/exit 1) seemed to work but is this the right one to use?
What do I select for the motion or smoke detectors?
