Jump to content
Help identifying a stepper motor
  • Please log in to reply
10 replies to this topic
#1 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 20 November 2016 - 02:40 PM
I am trying to find a replacement for a motor in a swimming pool cleaner robot part# 55BYC406L-001. I found the part at the manufacturer's website in China and translated it to English but they will only sell a minimum 1000 pieces. It is a gearmotor with 1:25 reduction but my gearbox is fine and I would be happy to get the electric motor alone if I can't find the motor/gearbox assembly.
Now I am trying to identify a suitable replacement but I don't know enough about stepper motors to be confident choosing one. It is a 55mm 24vac deceleration stepper motor. The torque specs and some other stuff is in the following link.:
http://s609.photobuc...tml?sort=2&o=14
and this:
Brands XINTE / new special model 55BYC406L
rated power 3 (W)
product type Deceleration stepper motor
Rated voltage 24 (V)
Current Rating 0.4 (A)
Rated torque 450 (NM)
Dimensions 55 (mm)
Mike.
Edited by mikefamig, 20 November 2016 - 02:48 PM.
#2 DELInstallations
DELInstallations
    Cocoonut
  • Professionals
  • PipPipPipPip
  • 5400 posts
  • Software:Custom
  • Hardware:Custom
  • Tech:ZigBee
  • Audio:Custom
  • Video:Custom
  • CCTV:analog, ip, dvr
Posted 22 November 2016 - 01:29 PM
Try Baldor over the hill from you?
#3 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 23 November 2016 - 10:13 PM
I don't think that they make small bldc stepper motors.
#4 DELInstallations
DELInstallations
    Cocoonut
  • Professionals
  • PipPipPipPip
  • 5400 posts
  • Software:Custom
  • Hardware:Custom
  • Tech:ZigBee
  • Audio:Custom
  • Video:Custom
Posted 25 November 2016 - 05:36 PM
They might be able to rebuild what you have or steer you.
#5 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 02 December 2016 - 02:07 PM
For anyone who is interested....
I worked with tech support at Kaman Corp and they tell me that they can not find a good xref for this motor. I also contacted a manufacturer in China and they tell me that it is common to make custom motors for large customers like Aquaproducts.
The bottom line is that it is a common DC stepper motor but it is 24vdc, 8 ohm coils and and 15 degree step attached to a 25:1 gearbox reduction. It is just not something that I can buy off the shelf and I'm ready to throw in the towel  on this one.
Plan B is to watch Ebay for parts machines.
Mike.
#6 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 02 December 2016 - 02:09 PM
Unfortunately this is a welded tin can motor and I tore the back bearing plate off of it to see what was inside so I don't think that it can be rebuilt. I found that the rotor bushings were burnt out.
#7 flyers2000
flyers2000
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 02 July 2017 - 07:40 PM
mikefamig- Did you find anything? I find myself in the same boat. I would rather replace the motor than pay $350 for a new drive unit.
#8 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 02 July 2017 - 08:34 PM
No. I did find the motor in china but there was a minimum 1000 unit purchase.
#9 eulerdman
eulerdman
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 25 June 2019 - 07:59 PM
This looks fairly close. Would something like this work? I see it is only 24 to 1 where as you are asking for 25 to 1.
https://www.digikey....e=1&pageSize=25
The next problem would be how to get the shafts the same, it sure would be nice to buy a new drive motor for under $35!!
#10 mikefamig
mikefamig
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3484 posts
  • Experience:novice
  • Hardware:Elk M1
  • Tech:UPB
  • CCTV:ip
Posted 26 June 2019 - 05:35 AM
Thanks for the link. It's been so long since I took that Aquabot apart that I don;t know if can wire a new one correctly anymore. I think that I took a photo of the wires before I removed the old motor but it'll be hard to find. I did store the parts in a bucket and will take a look at it later today.
Mike.
#11 martyreyes
martyreyes
    Newbie
  • New Member
  • Pip
  • 1 posts
Posted 21 September 2019 - 11:45 AM
mikefamig, I have the same issue finding this exact same stepper motor.  55BYC406L-001  .3A  8 ohm 15 degree,  I have pictures of it if you need the wire colors.  Let me know if you find something that works and I'll do the the same.  I just starting looking today and very resourceful looking for parts on line.  Thanks!
