Now that I've had this beastie cranking along these past few days I can begin to understand why people own more than one. Print times can be slow. Laying down filament in .4mm strands can make for very long print times.
All those little lines, back-and-forth, layer-by-layer...
The longest job I've yet printed was 5 hours. And that was a clamp for Dyson vacuum accessories. Works nicely, btw.
http://www.thingiverse.com/thing:1788378
The Cura slicer software gives estimates, both on print time and amount of filament to be consumed. It's a bit optimistic on time, as that 5 hour job was estimated at ~4:30. This is likely due to my not having the exactly correct specs plugged into it. There's a lot being calculated, including time to retract the filament before doing a move. I don't have my software precisely configured for all those little variables.
If I stick with this I'd likely consider something with support for 2 extruders. If just to be able to do prints with dissolvable support material. Prints need support just about anywhere there's an overhang of more than a millimeter (ramps can cantilever out a fair bit). The slicer software will attempt to do this for you. But then you need to manually clean up the print by snipping off the supports. With dissolving material you'd just dunk the print and it'd melt away the supports. But a second extruder could just as readily be used for another color, or even a different material.
Right now I've only been printing with PLA. There's a whole slew of other materials like ABS, PETG, Nylon, even a wood filler type. I picked up a sample bag of PLA, with a bunch of different colors. I think they're about 2m each of PLA. Enough for several small items. I've already made a few hose clamps pretty close to Festool green for my dust collector and track saw.
I don't know that "everyone" would find use for one of these. They can be made pretty trouble-free but they're still basically little automated glue guns. As such there's potential for setup issue, maintenance and any number of other complications. They're not yet at the 'inkjet printer' stage of evolution. Maybe still at the electronic typewriter stage, using separate inked ribbons, not yet using something like a Selectric cartridge. Which puts them just as far behind as a typewriter was from a color laser printer. Progress continues to be made, but it's no longer in the prototype stage.
