Jump to content
Existing haiku push notifications will end at the end of Feb 2017
  • Please log in to reply
71 replies to this topic
#31 lupinglade
lupinglade
    Cocoonut
  • Manufacturers
  • PipPipPipPip
  • 1514 posts
  • Experience:guru
  • Software:Custom
  • Hardware:HAI OmniPro II, Custom
  • Tech:UPB, INSTEON, Z-Wave, ZigBee, Custom
  • Audio:Nuvo
  • Video:AirPlay
  • CCTV:ip, dvr
  • Phone:Asterisk
Posted 01 March 2017 - 01:34 PM
Generally this is what you need to do:
- Open the Terminal on the Mac running HaikuHelper
- Type in: sudo nano /etc/hosts
- Enter your administrator password (you will be prompted by sudo)
- Add a line at the bottom: 199.19.85.253 push.haikuautomation.com
- Hit CTRL+X to exit, you will be prompted to save -- save the file
You can test if you have it working by typing:
ping push.haikuautomation.com
You should see replies from the IP above.
#32 jpposin
jpposin
    Newbie
  • Registered
  • Pip
  • 3 posts
Posted 01 March 2017 - 02:27 PM
Great. Just checking--is there a space between nano and /etc/hosts? I know that you have to be real careful with Terminal and sudo.
Also, once done, can I just use Haiku Helper on my Mac and test push notifications that way?
Thanks for the fast help.
#33 lupinglade
lupinglade
    Cocoonut
  • Manufacturers
  • PipPipPipPip
  • 1514 posts
  • Experience:guru
  • Software:Custom
  • Audio:Nuvo
  • Video:AirPlay
  • CCTV:ip, dvr
  • Phone:Asterisk
Posted 01 March 2017 - 02:30 PM
Yes there is a space. And yes once you make the edit you should be able to test it right away. Worst case you may have to restart HaikuHelper. Test with a ping first.
Edited by lupinglade, 01 March 2017 - 02:30 PM.
#34 jpposin
jpposin
    Newbie
  • Registered
  • Pip
  • 3 posts
Posted 01 March 2017 - 04:50 PM
Worked perfectly. Thanks. All good. BTW did not need to restart HaikuHelper.
Please keep us posted on your new app.
#35 networkcrasher
networkcrasher
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 177 posts
Posted 01 March 2017 - 05:39 PM
<command>+spacebar => type terminal, hit enter
echo "199.19.85.253     push.haikuautomation.com" | sudo tee -a /etc/hosts
enter your password
#36 BorderSecurity
BorderSecurity
    Cocooner
  • Registered
  • PipPip
  • 19 posts
  • Hardware:DSC, Elk M1, HAI OmniPro II
Posted 03 March 2017 - 04:44 AM
I did the edit (using the GUI, just added permissions on the folder and file), and clicked send test notification, and VOILA.
So thanks much for the info for this, saved my ass with some customers, and some income.  Hope to see some new stuff being released soon!
#37 BorderSecurity
BorderSecurity
    Cocooner
  • Registered
  • PipPip
  • 19 posts
Posted 03 March 2017 - 04:46 AM
So Leviton shut down this domain? Lame, they are pretty corporate aren't they
#38 networkcrasher
networkcrasher
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 177 posts
Posted 03 March 2017 - 08:58 AM
Not sure what Leviton would have to do with this.  It looks to me like someone else owns the haikuautomation.com domain.  Some place called marksmen.com owns it.  They're some sort of brand protection service.  My guess is nullriver got hassled by them, or didn't want their services anymore, and lost the domain for some reason (which seems pretty lame)
#39 SJHart
SJHart
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 323 posts
Posted 04 March 2017 - 12:21 PM
enter your password
Do you enter the quotes?    Assume this commands vs. adding the line (which I didn't understand in the original instructions)?  thanks.
#40 networkcrasher
networkcrasher
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 177 posts
Posted 04 March 2017 - 12:47 PM
all this does is append the ip and hostname to the end of /etc/hosts.  paste it in it's entirety in the terminal window
#41 networkcrasher
networkcrasher
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 177 posts
Posted 04 March 2017 - 12:48 PM
type
cat /etc/hosts
when you're done and it should show you the contents of the file
#42 al98t
al98t
    Newbie
  • Registered
  • Pip
  • 8 posts
Posted 05 March 2017 - 01:44 PM
thank you for the work around.. works great for now
#43 dwpaddack
dwpaddack
    Cocooner
  • Registered
  • PipPip
  • 60 posts
Posted 06 March 2017 - 08:24 AM
It is working only on one of our iPads, but nothing else. Neither my wife's iPhone or mine, or any other iPad. I've checked to make sure all settings are identical to the working iPad. Push notifications have always worked before. Any ideas?
#44 lupinglade
lupinglade
    Cocoonut
  • Manufacturers
  • PipPipPipPip
  • 1514 posts
  • Experience:guru
  • Software:Custom
  • Audio:Nuvo
  • Video:AirPlay
  • CCTV:ip, dvr
  • Phone:Asterisk
Posted 08 March 2017 - 03:18 PM
That change should not have affected the other iPads, so I'm not sure what might be causing that. You can try turning push notifications of and back on on the iOS device.
#45 dwpaddack
dwpaddack
    Cocooner
  • Registered
  • PipPip
  • 60 posts
Posted 09 March 2017 - 01:59 PM
I've tried that plus restarting my phone and haiku helper. Also, I've looked at my devices side by side to make sure all the settings are identical. Odd it only works on one device and none of the others.
