Third Party Access Control with OmniPro
nbharris10
Currently using the HAI access control Keypads on my system, but would like pin/prox functionality. Anyone successfully integrated a system like Rosslare with the Omni?
You can use most any keypad/PROX/RFID module with OP from serial to zone switch to relay - just depends on what you expect with the integration.  If the idea is to simply turn security on/off - that's easy to do.
I don't see anywhere where the OP will allow the extra data bits of the PIN to be passed with the credential?
So that would rule out the HAI as the "gatekeeper" so to speak, which would mean the ACS would be the primary and then drive a KS zone on the HAI to operate, but they would both be dissimilar.
I'd stand by the same question to the OP...what is the level of integration desired? Arm/disarm OP from outside only?
