Jump to content
Clearing a Fire Alarm
  • Please log in to reply
6 replies to this topic
#1 sdl5e
sdl5e
    Cocooner
  • Registered
  • PipPip
  • 20 posts
Posted 20 October 2017 - 07:03 PM
This may be more of an Omni question than a Haiku question, but If I clear a fire alarm remotely via Haiku and there is still smoke causing the fire alarm will the fire alarm activate again or is there a timeout that prevents it from re-activating for a certain timeframe.
#2 JFab Design
JFab Design
    Dedicated Cocooner
  • Professionals
  • PipPipPip
  • 211 posts
  • Software:Custom
  • Hardware:2GIG, DSC, HAI OmniPro II, Custom
  • Tech:Z-Wave, ZigBee, RadioRA2
  • Audio:Custom
  • Video:Custom
  • CCTV:analog, ip, dvr
  • Phone:Vonage
Posted 20 October 2017 - 07:20 PM
I believe the Omni will keep trippIng as long as the smokes are tripped. I used too much smoke on a head before and it tripped on and off for a period of 5 minutes or so.
#3 heffneil
heffneil
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 640 posts
Posted 28 October 2017 - 01:53 PM
You have to disarm with a code if I remember correctly.
#4 sdl5e
sdl5e
    Cocooner
  • Registered
  • PipPip
  • 20 posts
Posted 28 October 2017 - 02:15 PM
The scenario was that my fire alarm went off when I wasnt home. Received a notification on my phone. I checked my cameras in the house and everything looked ok. Cleared the alarm with Haiku via entering code. Alarm company called and I told them to cancel fire dept response.
Just still curious if there actually had been smoke that I didnt see on my cameras (they dont cover every area), would the alarm have gone off again and would I be notified via Haiku.
#5 neillt
neillt
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 414 posts
  • Experience:guru
  • Hardware:HAI OmniPro II
  • Tech:UPB, ZigBee, 1-Wire, RadioRA2
  • Audio:Russound
Posted 29 October 2017 - 10:35 AM
Yes, that's what would have happened.
When you disarm the panel via a code, the Omni kills the power to all the smoke detectors for a second to reset them... then powers them back on.
If the smoke alarm trips again, if you have verify smoke alarms set in the configuration, it will even kill the power again to re-reset one more time.
If the smoke is still there, the detector will trip again, and the panel will go off again, and you will get a notification again.
#6 ano
ano
    Cocoonut
  • Registered
  • PipPipPipPip
  • 3455 posts
  • Experience:guru
  • Tech:UPB, ZigBee
  • Audio:HAI
  • Phone:Ooma
Posted 30 October 2017 - 12:27 AM
Actually that isn't completely true.  When the arm is deactivated, the smoke detectors are not deactivated, so you can walk around the house and see which detector tripped. Some have an LED that tells you they are tripped, so the tripped detector LED should be flashing.  When you activate the OPII, that is when the smoke detectors are reset.
Edited by ano, 30 October 2017 - 12:31 AM.
#7 sdl5e
sdl5e
    Cocooner
  • Registered
  • PipPip
  • 20 posts
Posted 30 October 2017 - 08:11 AM
Thanks for the explanations.
