Jump to content
What serial port type for Leviton Power Hub 83A00-1
  • Please log in to reply
2 replies to this topic
#1 kwschumm
kwschumm
    Cocooner
  • Registered
  • PipPip
  • 80 posts
Posted 20 April 2018 - 03:49 PM
Thanks to StarTrekDoors for the tip about using the Leviton Power Hub to offload power from an OmniPro II.
I've read the 83A00-1 manual, and the OmniPro II manual, and have not found how the OPII serial port should be set up when this hub is connected.
Should the serial port be set to type 3 for Omni-Link? If not, what should it be set to?
TIA
#2 StarTrekDoors
StarTrekDoors
    Dedicated Cocooner
  • Registered
  • PipPipPip
  • 191 posts
Posted 27 April 2018 - 05:35 PM
You don't have to connect the serial port if you don't use it.  Serial is for card readers and similar.  Controller on the power hub is connected directly to the console A/B connections on the Omni when using consoles.
WARNING: Read closely about SW1 because you need to set it appropriately depending on the devices you connect to the hub to avoid damaging your Omni.
#3 kwschumm
kwschumm
    Cocooner
  • Registered
  • PipPip
  • 80 posts
Posted 27 April 2018 - 06:43 PM
So you're saying that for only console connections (not Touchscreen) only the A/B connection is needed? That makes it easy. Thanks!
