Jump to content
ELK-M1DBHR
  • Please log in to reply
2 replies to this topic
#1 Mridixon
Mridixon
    Cocooner
  • Registered
  • PipPip
  • 28 posts
Posted 26 May 2018 - 11:01 AM
I'm a little confused. If you have 2 Keypads and you have them on branch #1 (homerun)each keypad should have a terminating jumper on it but should a jumper be moved on the data bus hub?
#2 BraveSirRobbin
BraveSirRobbin
    Cocoonut
  • Moderators
  • PipPipPipPip
  • 7492 posts
Posted 26 May 2018 - 11:37 AM
Not exactly sure what your setup is, but I think it is second example from the manual (see attached screen shot).
Attached File  M1dbhr_Screen_Shjot.jpg   251.68K   9 downloads
In that case you would terminate each keypad, but not the one on the DBHR
Edited by BraveSirRobbin, 26 May 2018 - 11:40 AM.
#3 Mridixon
Mridixon
    Cocooner
  • Registered
  • PipPip
  • 28 posts
Posted 26 May 2018 - 12:22 PM
     Reading a little bit more I see that my jumpers were set correctly and the hookup was correct. The issue was the keypad enrollment process and having 2 keypads with the same address. Thanks for the help!
